20 Most Recent Element Electronics FLX2211B 22 in. LCD TV Questions & Answers
To watch a DVD your player needs to be connected to the TV using a scart or RCA connectors (red, yellow and white) depending on the type of connections available to you. The easiest way to connect the DVD player to a television is via Audio/Video connections that are usually supplied with it.
Next plug in your DVD player and power it up.
Next use your remote to select AV 1, 2 or 3 or HDMI - depending on the input you used at the back of your TV. Insert DVD and play! For example, if the DVD player is connected to the SCART socket labeled Av1, then you need to select Av1 with the remote.
The use of your DVD player is not dependant on the dish receiver - it works on a serarate input direct to the TV. Connecting your DVD player in this manner direct to your TV will not affect your cable or antenna connection to your television.
Thanks for using FixYa. Please remember to leave a vote for the solution.
Element... | Answered on Jul 08, 2016
keep your reciept throughout your warranty period.
Element... | Answered on Dec 17, 2013
There is some short circuit at its main board. Contact any service technician.
Element... | Answered on Aug 29, 2013
sounds like v chip problem go into menu reset v chip to higher level . you will need password.
Element... | Answered on Jul 18, 2013
I have the same problem with my 360 i am just going to by a new tv i cant find the remote code. or any thing and the hdmi port don't work that's my answer this TV sucks and it is ****..
Element... | Answered on Jan 28, 2013
First place to look if total dead is inside for a fuse and then examine the power board inside for any puffed up filter caps.
Element... | Answered on Dec 14, 2012
May be its a resolution related issue? Did you try flipping through the various HDMI resolutions like 720i, 720p, 1080i and see if it gets the signal? If you haven't done so please do. I am positive that it resolve the issue.
Let me know if it worked.
Sai.
Check its speakers first. It found OK, check and replace damaged component/s in the audio output card.
Element... | Answered on Sep 28, 2012
Try e-mailing their service dept.
murf427
Element... | Answered on Aug 31, 2012
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
Element... | Answered on Jun 02, 2012
Try to change the setting of your picture size in the AV format.
Element... | Answered on Mar 08, 2012
Try Funai TV or Funai LCD codes. Can also try Symphonic and Sylvania codes.
Element... | Answered on Jan 06, 2012
Element Electronics FLX2211B 22 in. LCD TV Logo
72 questions posted
Top Element Electronics Televison & Video Experts
Steve Allison
Steve Allison
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Element Electronics Televison & Video
Most Popular Question
piture not using
  • Televison & Video
