20 Most Recent
Acer AT4220B 42 in. LCD TV Questions & Answers
Vertical hold
no modern set has a vertical hold control, last ones were nearly 40 years ago. what is set doing or not doing?
My Acer AT4220B 42in. LCD
Sounds like not only is your backlight going but you have a bad case of dead pixels. You can do 1 of 3 things...
Turn your unit in under warranty for repair
If your unit is no longer in warranty you can brave taking it apart and replacing the glass unit and back lights yourself... Find the make/model of the screen after removing the plastic casing and type it in on either of the bottom sites,
www.sparepartswarehouse.com
www.laptopscreens.com
Or last option, sell it on ebay and lie lie lie about the quality of the unit and make sure that somewhere on the listing you put as is
My ACER AT4220B LCDTV has sound but no picture.
This tv have a 2 long boards call the LCD inverter boards.These 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a 2 refurbishes long LCD inverter boards for the replacement.
I have a acer AT4220A LCD tv and the screen does
Hi
Thanks for using FixYa. From what
you have described it seems that you
might have a backlight issue with this TV set. It could also be due to the
inverter circuits for the backlights. The inverter is the power
supply source for the backlights. There could also be a screen driver
problem; if it is then you have to change the entire board. All this is only
recommended if you have some kind of expertise for checking the internal
circuitry of the TV as these units have high voltages running even when the set
is switched off.
Please do accept the solution
if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Acer PD116Pd Projector no powerup .
Please start by switching the outlet that you use to power your projector. If you're not currently plugging the projector into an outlet but using a power strip, you can test that the power strip is still functioning by using it with other items. Thank you.
What is my remote control number for Acer brand At3235b TV?
Statistical Process Control TrainingAll Acer TV models use the universal Remote Control code NEC 18E7, which most of universal Remote Controls can use. We recommend using the search function, available on most universal remote controls, to find the compatible code for your Acer TV.
