20 Most Recent Mitsubishi MS-A09WA Split System Air Conditioner Questions & Answers
3600 btu mitsubishi split ac
Good day,
I would like to have a model no. Things to look at. Is the filters clean? If yes then we carry on to the next step. Check power stability but that should not be the problem. Your next step is to find out what gas it's using. If using R410, then make sure there was no leak. If there is a leak you have to drop all the gas and weigh in new gas. On your system should be information on how much gas it takes as n standard. Every unit new come pre charged with gas for 10 meters. If your pipework is longer than 10 meters then additional gas should be added. If not it can take the amount that is shown on the info sticker.
You have to vacuum and put new gas. But you have to put it in as n liquid. If u canot do this yourself please call a qualified HVAC tech.
Thanks
1/5/2018 3:55:45 AM • Mitsubishi... • Answered on Jan 05, 2018
Mitsubishi split system will not start no green
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
2/5/2015 11:57:50 PM • Mitsubishi... • Answered on Feb 05, 2015
Samsung inverter SH12VA1
standard is the pc board,propably the indoor,samsung has codes for the boards and put them with the remote control.call them and tell them the model to give you the code to rearrange the pc board.and its not to difficult to put the code with the remote control.
1/11/2015 7:28:15 PM • Mitsubishi... • Answered on Jan 11, 2015
0answers
If you run a short lineset about 10 feet do you
No, a condensing unit has enough refrigerant to go about 35 ft or less, so less is noyt going to be a problem unless you added more than 35 feet and added more refrigerant even then 10 feet will not be much and not enough to adversely affect the operation
8/7/2013 3:07:17 PM • Mitsubishi... • Answered on Aug 07, 2013
0answers
I have a split unit
If your unit is only 8 months old, then it should still be under warranty! Suggest you check the drain line to make sure that nothing has decided to make it home.
I would check the level of your unit to make sure that there is a slight grade to the rear of the unit, but I hesitate to tell you to shim it.
7/26/2011 1:30:11 PM • Mitsubishi... • Answered on Jul 26, 2011
0answers
When turn on the power main switch after i have
Dint spray WD 40 for maintenance on the fins?? that does nothing good and apparently is dong something bad actually.
WD 40 means ,,,,, Water Displacer and it was their 40th recipe!!
Its great for removing roof sealants from your hands, or tar, oil etc, but a terrible lubricant
and the motors today require no oiling, so cut the WD 40 routine its not doing anything you want and is dong everything you dont want.
12/27/2010 10:01:03 AM • Mitsubishi... • Answered on Dec 27, 2010
Some times suctun line ice forming but gas is ok
icing bad or just abit? its normal to have water on it if its icing under the black foam insulation you have a gas problem gas leak, or a fan not working
11/10/2010 6:10:10 AM • Mitsubishi... • Answered on Nov 10, 2010
0answers
I have 2 of these units that are heat and ac i
The reset is to cycle the power.... turn off again for a few minutes and then turn back on.... but you may have blown a cicuit baord..
heatman101
8/30/2010 3:46:36 AM • Mitsubishi... • Answered on Aug 30, 2010
Compressor starts then stops after maybe 3 mins
Any error codes? If not there may be a mechanical fault with the compressor/inverter. The unit is possibly short on refrigerant, so the compressor is not getting enough suction cooling from return gas, so may be clicking off on its internal over temp klixon.
all the best
7/10/2010 1:53:10 PM • Mitsubishi... • Answered on Jul 10, 2010
Check light is on
The check light request the user to contact a professional to check the unit.
Hope this helps I take the time to help you so please rate me
6/28/2010 12:40:28 AM • Mitsubishi... • Answered on Jun 28, 2010
Mitsubishi MS-A09WA Split System Air Conditioner Logo
32 questions posted
Top Mitsubishi Heating & Cooling Experts
 Mikey
Mikey
vince
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Heating & Cooling
Most Popular Question
turn mitsubishi h1 split system
  • Heating & Cooling
