20 Most Recent
Maytag M6X08F2D Air Conditioner Questions & Answers
My maytag motor fan stops when gets hot
Most motors have a safety built into them. You have ether a bad switch or the motor is going out. When the motor gets hot a switch turns the motor off to keep it from catching fire.
My landlord installed this brand
The AC your landlord installed is rated at 8000 btu which is way too small for 900 sq ft. You need at least a 15000 Btu Air conditioner and a 'well insulated' house to be cool.
A good rule of thumb in the AC business says you need 1 ton (12000 btu) of Air conditioning for every 600 sq feet (if the house is well insulated) - if not - then you will need 1 ton (12000 btu) for every 400 sq feet.
So, if you have 900 sq feet and the house is well insulated you should have at least a 15000 btu unit.
If it's not well insulated you will need 24,000 btu.
