20 Most Recent Ace Hardware RAD-141A Thru-Wall/Window Air Conditioner Questions & Answers
If yo mean power socket, you can get it from electrical shop.
If you mean the input power, you have to use booster (Transformer_). 110vts to 220vts.
Thanks.
Ace Hardware... | Answered on Jun 29, 2011
change filter --clean coils --check freon --test compressor
Heating &... | Answered 6 hours ago
Outdoor temperature sensor problem
Heating &... | Answered 23 hours ago
this is a repair website. we dont do questions for any schools here
Heating &... | Answered Yesterday
Make sure to set your Temperature at 385 degrees Fahrenheit; the Time should be from 25 to 30 seconds. ...
Heat Press Time And Temperature: Guide And Instructions
  1. The Temperature setting should be at 270 degrees Fahrenheit.
  2. You should Time your heat press at 10 seconds.
  3. And you can only peel when it is hot.
https://tshirtprofessional.com/heat-press-time-and-temperature-guide
Heating &... | Answered 2 days ago
What is the "unit"? Are you referring to a fridge or freezer?
You are probably looking at replacing s thermistat sensor. Check with the manufacturer for the correct ohmage across the two leads.
It's not an issue, "SE" means you maybe by mistake set the unit to a "Super Economic" Mode, which will save you some power but won't give you the most of the unit, you can disable it anytime you like, just read the device manual, good luck :)
Heating &... | Answered 3 days ago
The Fan of the indoor unit is not supposed to turn off when the indoor Temp reaches the set temperature, but the indoor ambient sensor tells the outdoor unit that that's enough. Then, the outdoor unit minimizes the sound of the compressor. It is the normal operation of the Inverters. The Indoor motor fan doesn't turn off until you turn off the unit.
Why not contact Petra? Here is the link to their website which has contact details and product information.
https://www.petra-eng.com/product/apx
Pilot flame can be adjusted at gas valve something you may want to call a trained technician for. If the gas valve won't adjust down you may need to replace the gas valve. Also, celebrate valve ingoing pressure at 3.5 and outgoing at 4.0 & 4.5 of some
'this model'?
the secret one you don't tell us about!
Google
make model replacement thermocouple
Ace Hardware RAD-141A Thru-Wall/Window Air Conditioner Logo
1 questions posted
Top Ace Hardware Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
Are you an Ace Hardware Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Ace Hardware Heating & Cooling
Most Popular Question
need new power control unit plug old one
  • Heating & Cooling
