20 Most Recent Fitbit Zip Wireless Activity Tracker, Midnight Blue Questions & Answers
But now you should have figured out out
https://help.fitbit.com/customer/portal/articles/1031792-the-time-is-incorrect-on-my-tracker-s-display
Fitbit Zip... | Answered on Nov 02, 2015
Good question, are we referring to the Fitbit Zip?
If so I would remove the battery for 10 seconds then replace, this will restart the unit.
the pin that makes contact with and drives the nail is coupled to a piston.either that connect has failed OR the piston is stuck in a bind(probably a faulty o-ring)
Tools & Hardware... | Answered on Aug 14, 2019
Google (calhawk)(1000m/m)(manual) without parens.
Tools & Hardware... | Answered on Jul 25, 2019
It sounded good but made no sense. How do you remove the trigger/ squeeze handle assembly? This thing (Stanley TR70) is riveted together. The only piece that is removable is the staple feed tray.
Tools & Hardware... | Answered on Jul 22, 2019
This belt should be mounted so that the overlap trails when the belt sander is used, sometimes these belts will have arrows indicating the direction of rotation but not always. The arrows usually disappear after a bit of use anyway so if you change grits or re-use belts it is good to know which way to run the belt by looking at the join.
Here another fix that has worked for me. Take some ordinary electricians tape and make several laps around the idler pulley on the belt sander. Put more thicknesses near the center of the idler, than the outside. This effectively builds a small crown on the pulley and makes the belt stay centered. Also, always relieve the tension on the belt when not using the sander. The belt can stretch and tracks poorly if this happens.
Tools & Hardware... | Answered on Jul 17, 2019
Best place is to ask at a Canadian Tire. If you can find the part number on the rotor that would help a lot as you can search for that part specifically online or go to local small motor repair centre for the part or it's equivalent.
I have a brand new one here. It is made by Goodyear. Part number is 150XL037Pd. Made in the USA.
Tools & Hardware... | Answered on Jul 14, 2019
Fitbit Zip Wireless Activity Tracker, Midnight Blue Logo
15 questions posted
Top Fitbit Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Fitbit Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Fitbit Tools & Hardware - Others
Most Popular Question
will not keep time or steps
  • Tools & Hardware - Others
