Hey Anon, Download the TeamViewer software both on Windows and Android. On Android you will find it on Play Store and for the Windows, Click the link. Then Launch both. Enter the code you see on your TV (Team Viewer) screen on Windows in your TV screen on Android. Suppose you see the code BHAI, then enter BHAI on your TV software on android and you would be able to control your PC. Remember, TV generates a new code everytime you launch it. Hope you get it. Enjoy!
Mcalmond wakes up 5 year old post, ? why who knows.
but here is the correct answer. full
NO OS stated at all? (matters for drivers that work right) ok>
learn now (I have 8540w) that it takes 2 HP drivers for all this to work not just ONE.
the upper key led strip needs a HP only driver.
then the wifi card next.
this PC run on XP to W7 only !
if you upgraded to 10 , many things fail in this PC, for a fact.
ill not lest them but they well and for sure security features.
(all)
\wifi can be turned off many ways.
the top row on my elite book has WIFI led and button for it.
this turn on or off
airplane mode.
here the all are, just one click at hp.com and you land there.
https://support.hp.com/us-en/drivers/selfservice/hp-elitebook-2530p-notebook-pc/3782222
the
HP Quick Launch Buttons
must be loaded, called input devices catagory
or the strip WILL FAIL , so will sound controls and more.
Does not switch on? Do you mean you are unable to make Wifi enabled? If so, then it is suggested you contact HP support to provide the advice.
Before you speak to HP, you could try to update the wireless driver. A lot of wifi problem are caused by the outdated or corrupted driver. You could use a third party tool to scan your computer. OSToto Driver Talent is a good program. With this tool, the scanning result will be listed within a few seconds. Then you could if there is a driver issue.
Driver Talent Download Update and Fix Drivers Ostoto
Hi Eliza,
Enabling and disabling the embedded numeric keypad
Press fn+num lock to enable the embedded numeric keypad. Press fn+num lockagain to return to standard keyboard functions.
NOTE:
The embedded numeric keypad will not function while an external keyboard or numeric keypad.
Thanks Hope this helps!
Don't forget to rate:)
Gary
no you should service your fans and you need to replace the thermal past on your cpu. but remember that some laptops with Qcore chips gets were hot and the only thing you can do is to get extra fans. like a fan pad that you can put your laptop on will make a big difference.
Spywares or virus has affected registry and keyboard input program BIOS.....
Open the administrator and create a new user account with the help of on-screen-keyboard.
make sure tht the computer is malware free.....
Install good antivirus and antimalware software with recent updates.
There is wifi switch on laptop first turned it on.
Make sure wireless network adapter driver installed and enable you can check it in device manager.
Press Fn+ F5 key turn the wifi on.
Then you can view available wifi networks.
Let me know if you need further assistance.
Thanks for using FixYa.
Try boot linux live cd and beck up your data from hdd to cd if hdd works and reinstall OS if it is posible if it is not posible then find a warranty card and the nearest service center
I'm not 100% sure this will work but you might have to take apart the laptop to reSEAT the bios battery. Unplug it from the motherboard then plug it back in. Usually once those pre-windows passwords are locked in they're locked in for good.
