20 Most Recent
HP w2558hc 25.5" Widescreen LCD Monitor Questions & Answers
I can't open HP MediaSmart Webcam
w2558hc
what PC?
what OS? stated,
nobody can help you , unless the whole system is stated,
in details.
guess :1:
it wont work as supposed to because you have added other non HP software related to CAM, and they are in conflict.
remove that conflicting software
or do a HP OS refresh. using HP restore.
How do I oben the back cover
need a plastic wedge tool to pry the front cover from the back. There are latches inside the cover which are interlocked, needing the plastic wedge tool to unlock them. We used to call these a "mac cracker" tool.
No sound
http://www8.hp.com/us/en/support-drivers.html autodetect for your driver
How do I resolve image on screen shaking?
Hope you are talking about a computer. Do you have any electrical objects near your PC? Stuff like radios,
phones etc cause waves on your screen because of the waves that they
produce to communicate...magnets can also cause this...just things to
look out for...also try the connects on the back...screen waves could be
due to this!If the solution was helpful, pls rate and leave a commentThanks.
My monitor for my laptop is frozen and static. I
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive)))
defragment your hard drive will speed up your computer
then defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
hope this helps
don
My Monitor will only "turn on" for one second at a
It goes black because the circuit detects a problem (perhaps a short circuit) and shut downs the power to protect itself. This may be caused by a capacitor or transistor at the Fluorescent driver area.
It can be fixed, but you need some background on electronics removing and installing electronic parts.
Here is how to fix a similar issue: http://www.josepino.com/?howto-repair-dell
I hope this helps.
Every time i try to
I've had problems using a widescreen monitor with certain programs/devices when my horizontal resolution is set high enough (for example: 1024), but my vertical resolution is too low (for example: 700). This may be your problem check the display settings and increase if necessary.
Hope this helps you.
Thanks,
Steve G.
The avatars on my hp webcam dont move. how do i get them to move?
Go to the HP Support page for your computer and operating system. Go to the Software & Driver Downloads page. Download the latest version of HP MediaSmart Webcam Software listed under Software - Multimedia. 2010-04-23 , Version:4.0.1.2626 C, 119.16M This package provides the software to support the HP MediaSmart Webcam in the supported notebook/laptop models and operating systems.
