20 Most Recent
Genius Look 315FS Web Cam Questions & Answers
When i use to open my acer built in web cam
Go to control panel, double click system , click hardware tab and click device manager. Check there if you can see your Genius Look 315FS Web Cam is installed. If none or there is a device with a question mark. That means not yet been installed. Or try to switch your webcam to the other usb port if your computer detect just click next and so forth and if asking for the driver install it and test. Good day. Always remember for the compatibility hardware. It must be compatible according to operating system. Good Day.
No video capture device was detected on your
Copy this site and paste it in your browser ADDRESS
Bar and hit ENTER;
http://www.free-codecs.com/AMCap_download.htm
to download the Free AMCAP Video Capture Program.
AMCap v9.20
AMCap is a small yet fully functional video capture application compatible with Microsoft
DirectShow. It is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports
still captures to BMP, JPEG and PNG formats and it remembers your Video Input, Video Standard
and Video size settings from previous session. It has some nice features like multi-monitoring support, zooming, aspect ratio and interlacing features.
program.
AMCap is a small and effective piece of software and definitely worth trying.
Hope this will help. Bud
My genius 8mo granddaughter somehow swapped the w,a,s,d keys with the arrow keys. How do I swap them back?
are you talking like off of the keyboard? they snap off but not always back on- simply pry the keys up and place the key in the desired spot with the correct orientation and push down firmly supporting the natural action of the button. do this for every button- if the keys were switched software method (it should not) most computers don't allow you to reassign keys but some might, in this case you would need to follow the manufacture instructions to revert the setting or simply uninstall the software but I'm almost sure your talking hardware because not many code writer will "hook" the keyboard- or change your keypress- its considered dirty practice. Good luck
