20 Most Recent
Nitro BMW-483 Car Amp Questions & Answers
I dont know where the positive and negitive input
AT THE CONNECTION INPUT SLOT FEMALE PORT THE UPPER AND LOWER PINS IN THE CENTER AND BOTH NEGITIVE AND ARE A COMMOM NEGITIVE CONNECTION POINT THEOUTER PINS TO BOTH SIDES ARE THE POSITIVE CONNECTION PINS 4 TO EACH SIDE OF THE NEGITIVE CENTER PINS THIS IS PROVEN EASY WITH ANY OHMS METTER THE UPPERNEGITIVE SUPPORTS THE UPPER POSITIVE INPUT OF HIGH INPEDENCE INPUTS
I have the Nitro BMWX 483 4 channel amp, BMWX 484
From what I have read about this EQ it is just for subsonic frequencies. You really don't want to run your components through this EQ. Leave the components running off of the 4 channel amp and your sub box on the two channel with the EQ in series between your head unit and the sub amp.
Nitro 483 amp where do you hook up the power it
Fused 12 volt power wire from the battery connects to +12V at the amp. Chassis ground wire connects to gnd at the amp. Switched 12 volt power wire (accessory) (remote turn on from after market radio) connects to rmt at the amp.
