20 Most Recent
Element Electronics PLX4202B 42 in. Plasma TV Questions & Answers
Power supply regulator board
I HAVE A 42 IN ELEMENT PLX4202B IT SHUT OFF NOW I WONT TURN BACK ON RED INDICATOR LIGHT IS ON SO I KNOW ITS GETTING POWER BUT NOTHING HAPPENS CAN SOME ONE HELP ME
10/5/2016 9:22:36 PM •
Element...
Answered
on Oct 05, 2016
Picture is to large for
Check your ASPECT, Screen Size, or Format button on the TV Remote. You probably have it set to Zoom. If you still have an issue, post a comment and I will help you further.
9/7/2015 8:09:10 AM •
Element...
Answered
on Sep 07, 2015
40' plasma....black screen but audio excellent
There are some common reasons for this fault to Plasma displays. Buffer boards should be checked. If you wish to get more details about these checks, try the site linked here. It has details with illustrations to fault that occur to a Plasma Display.
http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type
in the Brand name to your set in its search box, or view it in
Mosaic /
Timeslide / Flipcard option.
7/25/2013 2:22:51 PM •
Element...
Answered
on Jul 25, 2013
Takes forever for picture to
Picture taking too long to appear is undoubtedly due to faulty capacitors on the sustain boards. Replacing these components should resolve the problem. How good are your soldering skills?
2/13/2011 3:17:55 AM •
Element...
Answered
on Feb 13, 2011
New TV is hooked up
jason_janick
You have settings in your TV and satellite receiver to set the resolution for the picture. I would first go into the TV settings and use 1080p for the TV resolution. Also, in the receiver setting, you have the HDTV setting. From the main menu, press 6 (System Setup) and then 8 (HDTV Setup). For TV Type change to 1080i. The Aspect Ratio should be 16:9. I hope this helps.
Ray Calo
DISH Network
2/2/2011 3:47:04 PM •
Element...
Answered
on Feb 02, 2011
I have an element 42" plasma, we were watching a
staceydesjar
Try unplugging the receiver from your electrical outlet for 10 seconds and plug back in. This will cause the receiver to reboot and re-acquire the satellite signal. After this, you should get your picture back. I hope this helps.
Ray Calo
DISH Network
2/2/2011 3:38:31 PM •
Element...
Answered
on Feb 02, 2011
My element tv comes on
chevelestes
I would try unplugging the TV and plug into a different electrical outlet. See if the TV does the same thing. If so, it may be the TV. I hope this helps.
Ray Calo
DISH Network
2/2/2011 3:34:11 PM •
Element...
Answered
on Feb 02, 2011
