20 Most Recent
RCA L46FHD37 46 in. LCD HDTV Questions & Answers
My RCA L46FHD37 with a Usb port won't play the
The RCA L46FHD37 can only play MP3 audio files and display JPEG image files from a USB drive. See page 41 of the manual to see the details on using a USB flash drive with this TV. I found the manual here:
http://www.hdtvsolutions.com/pdf/L46FHD37_0.pdf .
You will need to connect some type of computer with a video player to watch videos. Media streaming boxes, the Stick Computers (like the Intel Compute stick), some tablets/phones and most laptops would be able to connect to the L46FHD37 and display your video files. Some DVD and Blue-ray players will also be able to display these videos, depending on the format and codecs.
I wish that I had better news for you.
Nosound no analog signal can get digital but has
I'm not joking when I give you this "fix". UNPLUG your TV from the wall and let it sit for at least 30 minutes. (Don't JUST turn it off, UNPLUG it) I've fixed several TV sets with no sound this way. This allows the microprocessor to do a "reset" and sometimes works.
RCA 46 won't change channels
For ANY technical help (to begin with), it's necessary to know the Model Number that's printed on the back of the TV. The date of manufacture is also sometimes helpful (which is printed near the Model Number). Let's start there if you're willing and capable of some technical adventure.
Scenium l46fhd2x48y
If you notice this in all the inputs, there is a problem in the TV. Check the input cables also for loose contacts. Look for jammed buttons on remote. If you notice problems still, it is better to refer it to a qualified service technician.
RCA 46in LCD HDTV - Will Not Turn ON
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves
checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
I just set up my new 46
walmart should take care of you just bring the order number or get a reciept online from where you ordered it but i think walmart will take care of you
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.)
I hope this helps.
(One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI
copy and paste link for manual
https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them.
Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse .
TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com
Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
What is the code for remote control for RCA model# RT 1971-AC
Better idea
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com
https://www.amazon.com > Replacement-DETG160R-...
Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control.
US$32.99 · In stock
RCA RT1971AC Replacement Remote
Remotes.net
https://www.remotes.net > products > replacement-rem...
If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems.
US$34.90
RCA Universal Remote Codes:
- The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
- The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
- The cable box codes are: 000 and 027.
Apr 26, 2023
