20 Most Recent
AOC L22W861 22 in. LCD HDTV Questions & Answers
I need to rescan and
Press Menu on remote.
Press the left arrow to get to Channel menu.
Press down arrow to get to Auto Scan.
Press right arrow.
Select Digital channels and scan.
Forgot my parent control password and i cant watch tv
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Can't get the tv input to come up. all i get is no
Unplug tv and cables or satalites boxes,replug both back like an hour later.Now the tv it resetting itself back to factory setting.The cables or satalites boxes is resetting and it upgrading it softwares.The tv should work now.
WHY IS MY LCD TV CHANGING COLORS?
Check ur input tv signal?like it tight,if u use a HDMI cable.Replaced this HDMI cable.Not work after this.Than ur Main Tuner board is dead.Must replaced this board.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Pink Dot in dark areas?
Its a panle problem you can press that dot and see its going or not as per warranty terms in your warranty card is given how many dead pixel is allowed
How can i put the cable option on my TVs menu
you have to buy a converter to transform the rf to a/v,
the cable is a rf, connect it to a converter and have a/v out put which you can connnect to your tv a/v in put connection.
this will help you to interconnect the two components.
okay
AOC 24G2U all buttons only control the input since this week, can't access the settings menu and the screen will start to switch input by itself?
If the buttons on your AOC 24G2U monitor are no longer functioning as expected, and you can only control the input/source selection, it indicates a possible issue with the monitor's control panel or the firmware. Here are some steps you can try to troubleshoot the problem:
- Power Cycle: Turn off the monitor and unplug it from the power source. Wait for about 1-2 minutes, then plug it back in and power it on again. This can help reset the monitor's internal settings and may restore the functionality of the buttons.
- Button Combination Reset: Some monitors have a button combination or sequence that can reset the settings to their factory defaults. Consult the user manual for your AOC 24G2U monitor or visit the manufacturer's website to find the specific button combination for resetting the monitor's settings. Follow the instructions carefully to perform the reset.
- Firmware Update: Check if there is a firmware update available for your monitor model. Visit the AOC website or contact their customer support to inquire about firmware updates. Updating the monitor's firmware can sometimes resolve issues with the control panel and restore full functionality to the buttons.
- Physical Inspection: Inspect the buttons on the control panel for any signs of physical damage or debris. Sometimes, dirt or debris can interfere with the proper functioning of the buttons. Use a soft, lint-free cloth to gently clean the buttons and the surrounding area.
- Contact AOC Support: If the issue persists after attempting the above steps, it's recommended to contact AOC customer support for further assistance. They can provide specific troubleshooting steps or arrange for repair or replacement if necessary.
Please note that the steps provided are general guidelines and the exact steps or options may vary depending on your specific AOC 24G2U monitor model. Always refer to the user manual or contact the manufacturer's customer support for model-specific instructions.
