20 Most Recent
Vizio VO37LHDTV10A 37 in. LCD TV Questions & Answers
Blue screen vizio vo371
Blue screen could be a bad main board or a no signal issue---do you get picture with DVD player connected?
1/16/2022 11:39:24 PM •
Vizio...
Answered
on Jan 16, 2022
Vizio tv will not turn on
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
7/26/2014 4:09:55 PM •
Vizio...
Answered
on Jul 26, 2014
VIZIO TV DOES NOT TURN ON
Please be sure that the wire is in and the power is on and you press on the control comand on power button or 1 button......If the tv is on there should be a red or blue light open....
6/9/2014 8:24:17 PM •
Vizio...
Answered
on Jun 09, 2014
Vizio xvt3d580cm has red contour lines in dark
Does it do this using more than one input? Have you tried using a different source such as DVD? IF using HDMI inputs does it do it on all of them? I have seen this trouble because of configuration issues with some satellite boxes also have seen similar issues because of a bad HDMI input.
3/6/2014 8:53:30 PM •
Vizio...
Answered
on Mar 06, 2014
VO37LHDTV10A 37 in Remote malfunctioning
Cheapest route is to get a universal remote and start over. Most remotes have their life span. Sometimes shorter. Any abuse of the remote by dropping, getting wet, etc will make it quit. Hazards of a little piece of equipment we don't see as important UNTIL it does not work!
3/6/2014 8:50:56 PM •
Vizio...
Answered
on Mar 06, 2014
VO37L HDTV10A backlight on, get sound, no picture
TV sets that have been exposed to significant surges can have multiple boards that are damaged. If the backlights are indeed firing, and you get no picture, you may have a problem with the T-Con board, assuming the main board is working properly. This is exactly why I steer people away from repairing sets that have been hit with large surges. In most cases it will be cheaper to buy new sets vs. repair them.
1/17/2013 6:24:01 AM •
Vizio...
Answered
on Jan 17, 2013
My Vizio VO37L dropped from a small height and now wont turn on
I would take a very close look with a flashlight first at the screen unit for any signs of cracks etc. The display panel is very fragile and if damaged this is fatal cost wise.Since you may have nothing to lose I would open set up and have a good look inside for any signs of physical damage.If you need to know the safe way to open let me know and I will explain.
5/23/2012 2:36:00 PM •
Vizio...
Answered
on May 23, 2012
What is the picture quality setting for a panasonic 1080i HDTV
Adjust the video output settings on the devices connected to your Panasonic HDTV. To view 1080p programming, enter into the service menu on your external device and change "Video Output" to the appropriate resolution. By default, the Panasonic TV is always displaying content in the resolution provided for it by the external device. If your cable box is set to output in "1080i," for example, your TV will display content in 1080i.Let me know if this fixes the issue.Regards,Suhail
5/11/2012 9:12:25 AM •
Vizio...
Answered
on May 11, 2012
