20 Most Recent
Haier HLC19R 19 in. LCD TV/DVD Combo Questions & Answers
MODEL HLC 22 R TV/DVD COMBO
This is the best solution for your problem as a 40 year experience with wires etc.
Go to the source of your cable signal connector .
Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires.Switch input mode
Vitally
Problem with haier plasma tv model number:45HP25SAT
Visit the site named 'Electro-help' for more
details. Check this link and select the
site named above. View it in 'Flip card' option, which can be
selected from the drop down box menu at the left top corner or the display
window. It will make search easy. Some times, the ads attached with each posts
might help you to find the availability of spare parts. There are more than 640
posts to different brand TVs.
Dvd is stuck in tv/dvd combo
here you can mess the unit up completely if your not carefull,,some of the many different types of system unit have a small hole on the door itself,carefully power on then push a straightened paperclip into this hole,,if you can find one that is,,your only other options would be to use a very flat knife and try to time pressure on the door in conjunction with the power on button the door itself is ,or can be operated by internal cog mechanisms which can break easily--good luck--Davey
Dead on turning on, no sound or picture
Try this;
Turn the set on and place a
bright flashlight against the screen. If you do
not see an image around the edge then look to the
power supply board.
If this set is under warranty you should return it to get it fix/replace. If not then;
This sounds like the power supply board has failed. The electrolytic capacitors on the board may need to be replaced.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(soldering ) or have a friend with knowledge/skill you can fix it.
>Unplug the set and any cables.
>Remove the back cover.
>look at the capacitors on the power supply board. If the top of any of them are bulging up then that is a problem.
>You will have to replace ALL the electrolytic capacitors except for perhaps the large one.
>Disconnect and remove the power supply board. Handle by the edges to prevent contaminates and static electricity.> Use ones with the same farad rating
> Use ones with the same or higher voltage rating> Use ones with high temperature rating> Install one at a time to prevent mix-up and keep the polarity correct.
> Leave a space between the PC board and the bottom of the capacitors for expansion. They heat up.> Replace power supply board and reconnect cables..> Replace back cover.
THIS IS AN INDUSTRY WIDE PROBLEM AFFECTING MANY COMPANIES AND PRODUCTS.
One source for some good capacitors is NTE. Try nteinc.com for a local outlet.You can also search for other sources. Some companies even sell all the capacitors in a kit.
Total price of parts should be < $20.00
Yes you can replace the power board but if the capacitors have not been replaced they will eventually fail also.
Need the operators manual
Hi, The link for downloading your manual in PDF format is ---->
HERE <---- it takes quite sometime to download.
or you can go ----->
HERE <---- and right click the HLC19R1-UM.pdf link and select 'Save as' or 'Save Link as' to save the fike to your PC.
Hope this helps.
How to reset menu password
Hello
The original initial reset passcode for your TV is '0000'. If you forgot the passcode you have entered just key in "9443", which will regain control over your TV. OK.
