20 Most Recent Sylvania LD-320SS8 32 in. LCD TV/DVD Combo Questions & Answers
0answers
P c settings on the tv
Don't try it...you go nuts
5/9/2014 3:10:34 PM • Sylvania... • Answered on May 09, 2014
Put cd in player upside down won work
I'm guessing you mean that the player won't open so you can take out the cd and turn it upside up. This method will work even with the CD player's power off. Get yourself a paper clip, regular size, not a large one. Straighten out one end of it so it sticks out straight. Get a bright light and look at the front of the CD player carefully. You will see a tiny hole just the right size for your straightened-out paperclip to fit. Stick the straight end into the hole and press. The CD tray should slide out, allowing you to turn the CD over. Hope this helps
5/1/2014 5:06:47 AM • Sylvania... • Answered on May 01, 2014
0answers
Why is it not turning off and why is it flashing different colors
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience.
3/27/2014 4:42:27 AM • Sylvania... • Answered on Mar 27, 2014
TV is not working
3/10/2014 6:11:39 AM • Sylvania... • Answered on Mar 10, 2014
Starting to get a get dark ghost on right of screen looks like a cloudmother says happed from use of the dvd
what you are describing sounds like a bad LCD panel tab. Does the problem clear up if you tap the top or right side of the TV set? If tapping the set clears up the problem, you have a bad LCD panel tab on the right side of the set. The only true fix in that was would be to replace the panel.
2/9/2013 6:31:58 AM • Sylvania... • Answered on Feb 09, 2013
Tv comes on, green light flashes several times,
common problem with that model is the backlight inverter, 1 or more of the six transformers may be bad.also check for bad capacitors.the tedious way to check is unplug each and plug in each one at a time but unplug the power from the tv each time you check one or you will get a nice jolt. the one that doesnt light the lamp is bad.or take each transformer off and check the primary and secondary coils if you find one open coil. the transformers cost between $8 and $20 each.it has a substitute part.
8/23/2012 10:44:26 PM • Sylvania... • Answered on Aug 23, 2012
Next
If you here clicking sounds inside you have shorted parts (transistor) and this trouble is all technical because you need further troubleshooting and soldering..
1/10/2012 9:51:45 PM • Sylvania... • Answered on Jan 10, 2012
My tv will not come
It goes into safety shutdown because it may have sensed faults in the set somewhere.
You need to look at the power supply caps first, then do some voltage checking before going further to the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on: Please see my basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series. Please post back what you find.
12/7/2010 4:18:21 AM • Sylvania... • Answered on Dec 07, 2010
We lost our remote control for our Sylvania
You are going to have lots of problems as universals will never have all the features needed for this type of set.
I GOOGLED the model number and the remote is available:
http://www.mcmelectronics.com/product/SYLVANIA-NF018UD-/NF018UD
Click on the above link in blue--you may find other sites with it for less---about 39 dollars plus shipping.
If this information helped you at all rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
8/13/2010 2:44:35 AM • Sylvania... • Answered on Aug 13, 2010
I bought this tv a year ago and just moved
First of all what you can check is for the power lines, whether the voltage is coming into the set. check inside for failure of the fuse and the power cord.if there is supply coming to the main board.If the supply is present then you will need to check for cracks, breaks inthe printed circuit board. you will have to be careful using a good lens to check for cracks that had occured on transit. hence the first priority should be to check for such cracks. if it is not possible to see the cracks then you will need to take the power section volt checks. if you trace the main power lines you will arrive at the fault.If not get a help to sort out in this manner. Good day
7/12/2010 10:30:51 AM • Sylvania... • Answered on Jul 12, 2010
Tv newer than verizon's fios remote as per verizon
follow the link for a pdf manual for the remote. Follow the instruction for What if None of the Codes Worked? That should solve your problem
http://www22.verizon.com/nroneretail/nr/rdonlyres/0d93f875-4498-460f-8fc4-a15d519b4e7c/0/welcomekitremotecontrolinsrt_nc.pdf.
12/14/2009 3:24:31 AM • Sylvania... • Answered on Dec 14, 2009
I don't have a problem I have a question. I have a
Most sets with digital tuners do this. The best thing to do is manually save them into memory, unless they are the same numbers, this would keep the channels tuned until you go back to them
11/6/2009 9:01:12 PM • Sylvania... • Answered on Nov 06, 2009
BLACK LINES ON PICTURE
could be capacitors are problem, hope you have checked al the input cables. need servicing and resoldering on main board...
10/21/2009 9:01:22 PM • Sylvania... • Answered on Oct 21, 2009
Sylvania LD-320SS8 32 in. LCD TV/DVD Combo Logo
34 questions posted
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
next
  • Televison & Video
