20 Most Recent
Panasonic TH-42PZ80B 42 in. HD-Ready Plasma TV Questions & Answers
My 2 days old Panasonic
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
5/6/2016 6:54:43 PM •
Panasonic...
Answered
on May 06, 2016
My Tv Panasonic TH-42PZ80BA switched into standby
Yep , I cannot remember offhand but one the the internal boards has failed. The flashing code is telling us which one , will have to check SM to tell you which board but it should be under warranty , get it repaired for free.
5/5/2009 8:21:34 PM •
Panasonic...
Answered
on May 05, 2009
Panasonic code
The code is 0051
on your sky remote press the TV button then
the select and Red button at the same time , hold until the led on the remote blnks twice
then press TV and enter code 0051 then press select and the remote will blink twice again to acknowledge the code
if you still have your Sky box manual all these details are in there also
im a sky engineer by the way , goodluck
5/5/2009 7:54:19 PM •
Panasonic...
Answered
on May 05, 2009
Remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
4/8/2009 7:51:51 PM •
Panasonic...
Answered
on Apr 08, 2009
Random Side Panel Inputs
You either have a bad Main board or simply a bad touch control button in other word one of your side buttons is defective and it is blocking any other signal to the main board, but usually its a bad main board. In some cases ther is a FIRMWARE update from Panasonic, you may want to call Panasonic or check there website for any type of FIRMWArE UPDATE.
