20 Most Recent Toshiba Regza 42RV535U 42 in. LCD HDTV Questions & Answers
0answers
2answers
Toshiba regza 42rv535u not working, has blinking yellow light, light blinks 3 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience.
11/19/2015 4:42:39 PM • Toshiba Regza... • Answered on Nov 19, 2015
Remove stand
follow this link it will show you how .
1/27/2014 11:36:59 PM • Toshiba Regza... • Answered on Jan 27, 2014
Backlight Inverter Repalced still not working
dim the lights in the room, turn on the set, and shine a bright flash light on the screen. Do you see a faint picture? Also be advised that there are a lot of bad parts floating around on EBay. No backlight condition could be cause by a bad main board, power supply, inverter board, high voltage short on the inverter output, or a bad backlight bulb.
11/11/2013 6:24:52 PM • Toshiba Regza... • Answered on Nov 11, 2013
Where is other Back Light Inverter Board ?
Some sets only have one board. If you are having problems with no backlight, you also need to check the power supply which powers the backlight circuit. Usually it is 24 volts, so check for that as well.If everything checks out fine, also remember that the backlight itself can go bad.
11/8/2013 3:09:35 PM • Toshiba Regza... • Answered on Nov 08, 2013
Toshiba Regza 42RV535U42" LCD HDTV when i turn it
Check the power going to the inverter board (24V) if ok...replace Inverter board....
11/2/2013 3:02:30 AM • Toshiba Regza... • Answered on Nov 02, 2013
2answers
Will not turn on
they are famous for bad capacitors on the power board. You can get the replacement power board or a repair kit from www.tvrepairworld.com just hit the contact us button on the website if you dont see you model listed.
4/25/2013 3:22:08 PM • Toshiba Regza... • Answered on Apr 25, 2013
2answers
Can not find a panel or backlight for a toshiba 42RV535U lcd, seems obsolete
I would send a email to [email protected] they should be able to assist with that.
4/25/2013 3:16:57 PM • Toshiba Regza... • Answered on Apr 25, 2013
0answers
No picture, no sound, but TV will power up
Average life on all brands and models is 3 to 5 years. Average repair on this size and type of set varies but is usually from 150 to 250 parts and labor. I see very few sets of this type (any brand) that are more than 6 years old.The bulk of sets in our shop (over a hundred sets on average) that have failed are under 2 years of age.
12/20/2012 7:46:39 PM • Toshiba Regza... • Answered on Dec 20, 2012
TV needs back light inverter board replacement as discussed in chat session, required board is available with shopjimmy.com
Thanks.
9/24/2011 11:48:48 PM • Toshiba Regza... • Answered on Sep 24, 2011
No picture or sound, flashing yellow light, won't
Classic problem for this TV. Although I have not repaired this model, i do know I would suspect a bad capacitor in the power supply. If you know anything about electronics you can probably fix this. First of all there are at least two boards in this TV. The signal board is the one with all the RCA jacks and RF connection. Therefor the other board is the power supply. This is the board you will be working with. Look for a bulged capacitor or two. You must replace with same voltage or next higher and the Mfs must be exact. Be sure to use a high temp cap(105 degrees). Hope this helps in your repair. Good luck and show all hands for support!
3/28/2011 3:09:12 AM • Toshiba Regza... • Answered on Mar 28, 2011
2answers
Toshiba 42RV535U again. I detected
Are you blowing any fuses - if not, good. Hopefully nothing is shorted. Inspect the power board thoroughly for bad capacitors - look for bulging. Inspect the circuit traces for cold solder connections. Also, check the Zener diodes for a voltage drop - one of them may be bad. I don't think the inverter board is bad. I think you're on the right track - THINK!
3/24/2011 9:09:22 PM • Toshiba Regza... • Answered on Mar 24, 2011
The image is too wide
It would be helpful if I knew what else you had in the setup. Mostly I just need to know if you have a cable box, I will assume this is the case.
I had this problem with my Tv, if it running through a Bose system the problem is most likely with the Bose system, you need to go into the options and go to picture and select Full Screen instead of widescreen.
If you are not using a Bose system then the problem is still fairly simple.
  • Look at your remote for the Tv, locate the menu button and press it. A menu should come up.
  • There should be a video or screen option in the menu select it.
  • There should now be a wide variety of options to choose. Choose the normal option.
  • Then close the menu the video should now fit the screen.
If this doesn't work then it be your cable box, to fix that you follow the same steps just using your cable box remote instead of the Tv remote.
If this doesn't work comment and I will see if I can figure out another problem.
Hope this helps.
Chengeaj
3/7/2011 10:47:09 PM • Toshiba Regza... • Answered on Mar 07, 2011
42 inch toshiba\r\n tv screen
Dark picture. I adjusted brightness, but it keeps getting dark. It has vertical lines that can be seen in grey areas on the screen.
1/18/2011 2:33:53 AM • Toshiba Regza... • Answered on Jan 18, 2011
How do i get the
Lay down the tv picture screen on a soft flat surface.Check all the screws holes and take out all the screws.Take ur hand holding on to the tv and base stand tight.Pushes in and out few times.The base stand should came wright out..
12/24/2010 11:35:07 PM • Toshiba Regza... • Answered on Dec 24, 2010
Toshiba Regza 42RV535U 42 in. LCD HDTV Logo
38 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
REGZA Toshiba
  • REGZA Toshiba
Most Popular Question
toshiba regza 42rv535u not working
  • Televison & Video
