20 Most Recent Amana PTH153B50AM Air Conditioner Questions & Answers
switch issue.
Amana... | Answered on Aug 16, 2015
Check your compressor to ground. If there is continuity, time for a new one. Also check the condenser fan motor. If those test ok check all the electrical connections to ground.
Amana... | Answered on Aug 24, 2014
The unit was running when we came in. No Storms in the area. it was blowing hot air, but was still on the cool setting. There was a burnt wire smell coming from the unit. And the diag. code was Br. I found this odd since it still had power.
Amana... | Answered on Aug 16, 2014
yes it is fixable does the blower run? I would pull it out take it outside and wash with hose the outside coil and inside coil make sure you clean the outside coil real good on both sides. this may solve your problem.
Amana... | Answered on Jul 31, 2014
Jane, what you really need is the Owners Manual for you discontinued model AC/Heat Pump.
Call Amana Customer Support 1-800-843-0304 and they can furnish you one. Either by email attachment or by snail mail.
Hope this helps you. Please let me know.
Amana... | Answered on Jun 21, 2011
The only way to solve this problem is to replace the control board.
Amana... | Answered on Feb 13, 2011
First unplug the unit......Take the front cover off, take the wire screen off where the front fan is there is 4 or 5 screws that hold the plate that was under the screen. The electric heating elements are under that plate between the evaporator coil and the front blower wheel. It will lift straight up and give you access to the elements. In the electric heating element area there is a limit switch with a red or black button in the center of it push it to reset the limit it is on the right hand side by the controls. I wish I could find a picture to show you but I couldn't find one. It is not easy to get to... Hope this helps.
Amana... | Answered on Feb 12, 2011
Well, the solution is sort of a good news/bad news situation. It appears that the model number that you listed has been subject to a Safety Recall. This despite the fact, Amana no longer makes that specific model.
For further information and to make sure your specific model is included in that recall, go to
http://ptaccord.regcen2.com/
Amana... | Answered on Feb 03, 2011
there might be a reset button on the heat protector / you just might have a bad heat protector or the sensor on the board could be burnt out
Amana... | Answered on Jan 18, 2011
STATUS= Brown Out Protection engaged. Power was lost or voltage is low.
Check input power for right voltage.
And please note white is not mentioned as common for thermostat. If you want to check wiring for thermostat write again.
Amana... | Answered on Jan 12, 2011
Dear Friend! Er means Powerwas lost or voltage is low.
Do you believe if volt meter shows correct volts, it's perfect? No, even loose contact of neutral,burnt wire, it shows correct volts in that point.
Simple way to check the power is alright or not, just remove the a/c plug and connect any other device like electric racer, table fan, blower or iron box which work same volts as a/c. If other devices work, your power is o.k Or check for loose contact in your electrical wiring. Thanks.
Amana... | Answered on Jan 11, 2011
To getproper heat, keep your temp setting at 30+ degree and also mode in "heat "position.If still no heat, check your heating sensor for closed circuit by an OHMsmetre.It it's with RV, check power to RV
Amana... | Answered on Dec 16, 2010
Keep temp 30 degree and mode button in " Heat" Wait for 3 minutes. still problem, check heater-element/RV/Heater sensor.
its on a lockout. there is a safety switch that is open do you have a multimeter? If not iside the furnace is a red reset push button if you push that chances are you had flame rollout and you need to call the experts that means either you have a cracked heat exchanger or a blocked or not working inducer
I would replace the thermostat.
First - be sure and un-plug the Air Condtiioner from the wall.
When you 'select' the temperture I am assuming you are doing this with a 'knob' of some sort. This knob will be part of the thermostat - therefore it (t-stat) should be simple to identify.
Note: On some - LED/Electronic units - it may be difficult to identify the thermostat.
If, however, you can easily ID the t-stat - then you will have to dismantle the AC unit enough to get to the thermostat; it will be installed on/in the unit with screws of some type.
When you find the thermostat -- simply take the wires off the connections (these are usually - 'female' type spades that slide over 'male' type connections on the switch.
When you remove the wires be sure you mark them in such a way you can replace them on the "correct" terminals of the new thermostat without getting them mixed up.
It will be essential that the new thermostat - (A) physically fit the slot that the old one did, i.e. you can re-install it as the old one was and - (B) that it will have the connections you need - in order to connect your wires correctly.
If you take the old thermostat to an Air Conditioning Supply house they will probably be able to sell you an exact replacement - but in any event - an appropriate replacement - that will work.
good luck!
Amana... | Answered on May 10, 2010
change thermostat.
Amana... | Answered on Apr 30, 2010
Amana PTH153B50AM Air Conditioner Logo
29 questions posted
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
WatsHVAC
Level 1 Expert
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Heating & Cooling
Most Popular Question
made funny clicking noise shut off code
  • Heating & Cooling
