20 Most Recent
Hotpoint Ariston ASL65VXS Electric Dryer Questions & Answers
F 12
Hi there:F-12 means Communication ErrorFirst i suggest to check some bad connections,
wiring faults or a bad board.Try unplugging the dryer and
checking connections, wiring and the board for burnt or bad connections.Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.Thank you for using Fixya, and have a nice day.
The Dryer is heating but
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The
Dryer is not TurningDryer Repair - The
dryer will not startheatman101
Ariston dryer model asl65vxs flashing
F-12= communication error
Could be bad connections, wiring faults or a bad board. You can try unplugging the dryer and checking connections,wiring and the board for burnt or bad connections. Hope this helped Tim
Code F-10 it don`t dry
F10 is an error code associated with a faulty heating element. You MAY be able to fix this yourself if one of the overtemperature sensors has tripped. Unplug the machine, then try the following: On the back of the machine, the cover for the heater element os a metal bulge that can be unscrewed. Once this is done, there are 2 screws that hold the element onto the housing you have just removed. Undo these and you will see that (depending on the model) there are 2 or 3 overheat sensors. they look like a button with 2 tags on, with a wire connected to each tag. One of these will usually have a little pin hole in it. this is a reset hole, insert a paper clip into the hole and press down, hopefully you will hear a tiny click as the domed bi-metal plate that activates the cutout is pushed out and goes from being concave to convex again. Re-assemble and all should be OK. Things to think about here: Why did the overtemp sensor trip. Sometimes this can be because of a simple overload of drying, or because you didn't clean the filters. More oten than not I have to say, it is because the heating element is old and faulty and needs replacing (You may need to replace the overtemp sensors too) you can get all this stuff from places like Ebay and they are reasonably easy to fit if you are practically minded. The good news is these things fail safe, so the worst effect of trying to fix it is that it still wont work and you are highly unlikely to burn your house down
Hotpoint VTDOO dryer works but timer does not move and no reverse
sounds like you may have a timer with the contacts sticking closed at certian intervals. or a bad pcb check visual inspection of PCB look for burns or bulges, on the diodes or capcitors, Ihave in the past taken timers apart and fixed sticking contacts by sanding with emery cloth.
Hotpoint Aquarius dishwasher DWF34S/42 no power - possible fuse blown
Based on your description, it sounds like there was a short circuit in the dishwasher which caused the fuse to blow and the burning smell. It is possible that the burnt connection you are seeing is related to the short circuit.
If you have experience with electrical repairs, you can try to identify and replace the burnt connection. However, if you are not comfortable with electrical work, it is recommended that you seek the assistance of a qualified technician to avoid any potential safety hazards.
In any case, before attempting any repairs, make sure that the dishwasher is disconnected from the power source and that all safety precautions are taken.
Hotpoint TCFS93B is the motor starting to fail or ?
It is possible that the motor in your Hotpoint TCFS93B tumble dryer is beginning to fail if it is experiencing difficulty starting up and exhibiting similar symptoms to a failing capacitor. However, without more information or further diagnosis by a qualified technician, it is not possible to accurately determine the cause of the issue
The drum wont spin on my Hotpoint CTD00 dryer
Remove top cover, and see if the belt is intact, if it is then it could be the motor is not working for one reason or another, this would entail further investigation.
Please rate my solution.
Thanks.
