20 Most Recent Estate EED4300TQ Electric Dryer Questions & Answers
What is the part number for the heating element in a whirlpool estate dryer 2406026-fm54?
There are different ones, so you need to disassemble enough to get a good look at it, then click on this link to repairclinic.com http://www.repairclinic.com/Shop-For-Parts/a8b5c42-x776869726c706f6f6c2032343036303236666d3534/Whirlpool-2406026Fm54-Whirlpool-Dryer-Heating-Element-Parts and order it. . . They also have movies here giving you some direction on replacing your element . . You'll save a good bit of money . .
7/20/2014 6:31:35 PM • Estate EED4300TQ... • Answered on Jul 20, 2014
I dropped a toy down lint chute
There are 2 screws at either side of lint chute. Remove them. Make sure dryer is unplugged for next part. Remove back over by removing 1/4 drive screws. Looking at the back, on the left you will see the back of the lint chute. remove the four 1/4" screws around the bottom and lift and remove the chute. There you will find your toy. be careful around this as the edges are sharp.
5/31/2014 2:11:20 PM • Estate EED4300TQ... • Answered on May 31, 2014
How do you wire a 4 prong vs 3 prong
11/11/2012 5:27:58 PM • Estate EED4300TQ... • Answered on Nov 11, 2012
Dryer stop working has power going to all parts
Check the continuity of the thermal fuse, often the culprit. Also check the power relay. Sorry but I am not familiar with the Estate dryers. But the above are two common problems in a wide variety of electric dryers.
11/10/2011 2:53:16 AM • Estate EED4300TQ... • Answered on Nov 10, 2011
Model EED 4300TQO Dryer is cycling
Hi.
Start checking and eventually replacing the thermal fuse. That is the first part to replace when there is no heat. The fuse can be tested using a multimeter set on Ohms to make sure that its contacts are not open (impedance across its terminals is not Ohms infinity).
If the Fuse is not the problem test thermostats (there are three of them) and element itself. The parts have different impedance values. If any of the parts shows no continuity (circuit open), then the part must be replaced.
Here all parts and diagrams
Replacement parts for WHIRLPOOL EED4300TQ0
Here a repair of a different model showing in some more details testing procedures.
8/30/2011 11:43:04 AM • Estate EED4300TQ... • Answered on Aug 30, 2011
My dryer wont start
If you are having dryer problems and you cannot even get the thing to start, then you might want to start going through this check list of possibilities. There are a number of things that can cause your dryer to not run.
A couple of the most common problems are the thermal fuse has blown or the door switch is not operating properly. On many dryers if the thermal fuse blows, the dryer will not run at all. This fuse can be checked with an ohm meter. It should show continuity if it is okay. If there is no continuity then you need to replace it and also find out what else failed. This is a safety device that usually blows because something else allowed the dryer to get too hot. It is usually located in the back of the dryer, on the blower housing. Some are oval in shape and others are rectangular, usually with two wires attached.
A defective door switch or a bent door switch lever can also cause you to have problems. If the lever is broken or bent it will not activate the switch. If the switch is broken, this also will not allow the dryer to be started.
The push (or turn) to start switch can go bad, but is unlikely. To check this, hold it in or turn it and then check to make sure you have continuity with an ohm meter.
If the dryer starts and then stops when the switch is released check the control board or the ?even heat? control on some model dryers. Some dryers have a belt break switch that can fail or your belt may be way loose or broken.
Check for burn marks or burnt wires at the terminal block on your dryer, poor connections can cause all kinds of problems. Also poor connections can cause fires.
A bad power cord also falls into this same category.
Of course, always check that you have the proper voltage to the outlet that you are plugging into.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
6/6/2011 8:17:25 PM • Estate EED4300TQ... • Answered on Jun 06, 2011
My dryer tub doesn't spin anymore, it's heating
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
3/20/2011 8:20:53 PM • Estate EED4300TQ... • Answered on Mar 20, 2011
DRYER WONT GET HOT.
http://www.repairclinic.com/Dryer-Troubleshooting
3/5/2011 3:57:14 AM • Estate EED4300TQ... • Answered on Mar 05, 2011
Dryer heats up but does not dry very well.
disconnect vent tube run dryer and it should dry as the vent tube is restricted
2/24/2011 12:04:48 AM • Estate EED4300TQ... • Answered on Feb 24, 2011
Replaced heating element and it is still not
thermal fuse:
http://www.applianceaid.com/pictools/thermalfuse&stat.JPG
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
2/19/2011 2:10:55 AM • Estate EED4300TQ... • Answered on Feb 19, 2011
My dryer stopped heating and spinning in the
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
1/15/2011 4:00:20 AM • Estate EED4300TQ... • Answered on Jan 15, 2011
The drum on my dryer
See if the timer advances in the timed dry or the auto dry cycles. If the timer advances in timed dry but not in auto dry, then you could have a wire connection failure in the orange wire from the heating element to the timer.
If the timer will not advance in either type of cycle, then I recommend checking the timer part number that you are using.
1/7/2011 5:38:07 PM • Estate EED4300TQ... • Answered on Jan 07, 2011
Dryer stopped heating, in any
A dryer not heating is one of 3 things, the vent hose is clogged, the thermistors are blown, or the heating element is bad. Disconnect the dryer from the vent and turn it on to see if any heat is coming out the exhaust at all. If not then more than likely the thermistors are blown, there are two of them and they are mounted on the heating canister. They are kinda round or oblong shape with two electrical plugs on each one.
12/9/2010 6:37:27 PM • Estate EED4300TQ... • Answered on Dec 09, 2010
DRYER IS NOT HEATING UP
The problem here is the thermal fuse, to access the thermal fuse take the panel off at the back. Pull the wires off, and test with a ohms meter. If as i suspect is bad, take it out and replace it.
Any further questions feel free to ask.
11/17/2010 7:26:38 PM • Estate EED4300TQ... • Answered on Nov 17, 2010
Not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
11/4/2010 10:05:39 PM • Estate EED4300TQ... • Answered on Nov 04, 2010
Dryer dosent come on
heatman101
10/28/2010 3:02:12 AM • Estate EED4300TQ... • Answered on Oct 28, 2010
2answers
Replaced thermal fuse, thermostat, and timer,
I would check the door switch. Either the tang on the switch or the switch itself might be bad.
I would check power to the dryer. Number 10 is my primary suspect right now. You might have a bad motor you know. I looked up your dryer model number and it does not show a thermal limit like this one that goes next to the control thermostat:b74d06e.jpgc718aaf.jpgWhy yours don't show on the parts list is beyond me. More here If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
10/25/2010 5:34:51 AM • Estate EED4300TQ... • Answered on Oct 25, 2010
Dryer will not heat up what part could be bad
There are lots of pieces that can fail. BE AWARE that you can DIE from errors with 220 volts, only proceed if you are skilled. But meanwhile, most issues happen in the breaker box, only 1/2 of the 220 volt breaker trips and is not obvious. Turn the breaker off, push HARD into the off position, and then back on. Test dryer.
Stuff that fails in the dryer are the control switch, metal, like a bra underwire, in the element, quick disconnects (look for discolored and melted plactic), and thermal controls. Again, do not go in there unless you consider yourself an expert. it is only a very small error that gets you killed, 220 volts (and 110 volts) plays for keeps.
10/19/2010 3:51:51 PM • Estate EED4300TQ... • Answered on Oct 19, 2010
Wont heat it is like a fusr blue will move and run
Unplug the dryer and the first thing to do is check for the presence of 220 volts at the wall outlet. If you lost one leg of the 220 volts, it is possible for your dryer to run but there will not be any heat. Once you verified there is definitely 220 volts at the wall outlet, remove the rear cover. On the lower right hand side you will see a silver canister which contains the heating element. Remove the lower two wires directly from the heating element and check this for continuity. If it is good, on the left hand side of the same canister they often install a thermal safety which may have tripped. Do the same test as with the heating element. Remove the wires and test the thermal safety for continuity. If this is good, move to the blower housing on the left side of the exhaust vent and look for a white piece of plastic which has two wires on it. Remove these two wires and check this item for continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
10/9/2010 9:38:11 AM • Estate EED4300TQ... • Answered on Oct 09, 2010
Dryer does not turn and shuts breaker off when
heatman101
fsgs
9/30/2010 12:18:21 AM • Estate EED4300TQ... • Answered on Sep 30, 2010
Estate EED4300TQ Electric Dryer Logo
Popular Tags
54 questions posted
Top Estate Dryers Experts
Paul Carew
Jorgie  the...
Jorgie the...
Are you an Estate Dryer Expert? Answer questions, earn points and help others
View Most Popular
Estate Dryers
  • Estate Dryers
Most Popular Question
dryer will not heat up part could bad
  • Dryers
