20 Most Recent Oregon Scientific WW338H Weather Station Cordless Phone Questions & Answers
Operating Instructions Model No BA218
Setting the time and calendar
1. Press the [TIME] button once to enter Time Mode. The display shows the current time with hour, minutes, and seconds digits.
2. Press and hold the [SET] button for more than one second. The "Hour" digits of the time will begin flashing.
3. While the "Hour" digits are flashing, press the [^] or [down] button to set the desired hour time. Note: Press the [^] or [down] button once to advance the setting forward or backward by one digit. Pressing the [^] or [down] for more than one second will accelerate the forward or backward setting at a higher rate.
4. When the desired hour time is reached, press the [SET] button again. The "Hour" setting will be confirmed and the "Minute" digits will begin flashing.
5. While the "Minute" digits are flashing, press the [^] or [down] button to set the desired minute time.
6. When the desired minute time is reached, press the [SET] button again. The "Minute" setting will be confirmed and the "Year" digits will begin flashing.
7. While the "Year" digits are flashing, press the [^] or [down] button to set the desired year.
8. When the desired year is reached, press the [SET] button again. The "Year" setting will be confirmed and the "Month" digits will begin flashing.
9. While the "Month" digits are flashing, press the [^] or [down] button to set the desired Month.
10. When the desired month is reached, press the [SET] button again. The "Month" setting will be confirmed and the "Date" digits will begin flashing.
11. While the "Date" digits are flashing, press the [^] or [down] button to set the desired Date.
12. When the desired date is reached, press the [SET] button again. The "Date" setting will be confirmed and the calendar setting is complete.
6/29/2012 2:20:06 PM • Oregon... • Answered on Jun 29, 2012
Upon replacing the batteries, the
Hello. Chances are that the battery contacts in the outdoor unit are corroded due to exposure to moisture. Do this. Remove the batteries and clean the battery contacts in the device using the eraser end of a common pencil. Then reinsert the batteries. If that doesn't do it, go to any auto parts store and get a can of electrical contact cleaning spray and repeat the above steps. J.
9/14/2010 2:47:42 AM • Oregon... • Answered on Sep 14, 2010
I inserted sim1 but it still said on the home page
It may not have been put in correctly or there may be corrosion on the card. Make sure it is clean and inserted correctly.
If it is, make sure the SIM company matches the phone's company (AT&T, T-Mobile, etc).
12/19/2009 2:43:53 AM • Oregon... • Answered on Dec 19, 2009
0answers
Oregon esd90
Be the first to answer 12/18/2013 3:31:15 AM • Oregon... • Posted on Dec 18, 2013Be the first to answer
2answers
My sd memory card is broken when i kept in my poket
That cannot be fixed my brother.
7/9/2012 12:22:15 PM • Oregon... • Answered on Jul 09, 2012
I dont now my PUK a code i have orange berlin and
u can get it from the provider
6/7/2009 7:01:10 AM • Oregon... • Answered on Jun 07, 2009
0answers
I need a manual for a speakerphone 210 with a 13 memory an lcd
google speakerphone 210 manual for choices.
4/5/2024 12:49:29 AM • Lands Phones • Answered on Apr 05, 2024
How can I set up favourites on Eircom landline please?
Question edited for clarity. Question moved from Video Consoles category. Trying to find a manual. Are you sure that model is correct? Eircom should give you a manual PDF. https://www.google.com/search?q=Eircom+perform+100+manual and https://www.google.com/search?q=Eircom+perform+100 ..
3/26/2024 3:10:48 AM • Lands Phones • Answered on Mar 26, 2024
What is direct marketing?
Hello
Direct marketing is a sometimes controversial sales method by which advertisers approach potential customers directly with products or services. The most common forms of direct marketing are telephone sales, solicited or unsolicited emails, catalogs, leaflets, brochures and coupons. Successful direct marketing also involves compiling and maintaining a large database of personal information about potential customers and clients. These databases are often sold or shared with other direct marketing companies.
for more information visit http://www.wisegeek.com/what-is-direct-marketing.htm
Hope this helps if so do rate the solution
3/21/2024 10:02:08 AM • Lands Phones • Answered on Mar 21, 2024
Main Handset saying Out of Range, Other 2 alright tried re-registering it but no luck. Asked for a PIN number but I don't remember putting one in when I first set it up.
Good question but no 'make model (what it is). Base units have an antenna, make sure it is extended. Make sure the batteries in the satellite hand sets are good as they send out the signal to the base unit to be 'in range'. Not sure about the PIN request, refer to the manual. They are all online. Google make model manual ..
2/28/2024 6:57:13 PM • Lands Phones • Answered on Feb 28, 2024
SONIM XP 3800 VOICEMAIL INDICATOR STAYS ON BUT,NO MESSAGES=? TRIED POWERING OFF-PROBLEM STARTED 2/WEEKS AGO.
1. First, try resetting your phone by powering it off completely and then turning it back on after a few seconds. This can sometimes resolve minor software glitches.
2. If the problem persists, you can try contacting your mobile service provider and ask them to reset your voicemail on their end. They might be able to resolve the issue from their system.
3. Another option is to manually check your voicemail and listen to any existing messages. Sometimes, even if you've listened to a message, the indicator might stay on. By checking your voicemail and ensuring there are no unread messages, it might help clear the indicator.
If none of these steps work, it could be a more complex issue that might require technical support from Sonim or your mobile service provider. They should be able to provide further assistance. Let me know if there's anything else I can help with!
2/5/2024 4:27:32 AM • Lands Phones • Answered on Feb 05, 2024
Why is this section of the forum titled Lands Phones? The accepted label of Landline Phone has been used for decades. Why the plural form of Land?
Because when the site was started June 2005, it was staffed by IT kids adding categories on the fly as questions were being added. You can't expect youngsters to know basic English Language. The standard of written English in questions on this website is quite frankly, appalling. I edit nearly every question I answer, and many that I don't answer. I will see if I can get it changed. I have requested it and our other Admin said he also wondered why?..
1/30/2024 9:55:07 PM • Lands Phones • Answered on Jan 30, 2024
In my Yiboo UJ 820 controller, it is showing mode 2 on the display how can I change it to mode 1? Not the H&L
Usually pressing the mode button will toggle between modes.
1/24/2024 7:42:08 AM • Lands Phones • Answered on Jan 24, 2024
I have a D S E answering machine, on the bottom right of the machine there is a red light that is continually flashing. I have lost my manual so have no idea, A, what it's for, and B, how to fix it.
The flashing light is telling you someone has left you a message.https://www.google.com/search?q=Benchtop+10in+table+saw+05-30-13+%284002%29+manualWrong link. Edit to Addhttps://www.google.com/search?q=DSE+answering+machine+manual..
1/21/2024 8:17:12 PM • Lands Phones • Answered on Jan 21, 2024
Tevion T7 Corded Phone. It shows caller ID but won't speak it?
Unfortunately there is no online manual for it. Contact the maker direct. https://www.google.com/search?q=tevion+t7+manual
TEVION service
Teknihall benelux bv https://www.teknihall.be > service > tevion You can reach our service desk from 8:00 AM until 6:00 PM on weekdays, or you can write us an e-mail, without any time restrictions. When contacting us, please ... ..
1/11/2024 5:49:11 PM • Lands Phones • Answered on Jan 11, 2024
I need a manual for the XS2500 answering system. The On/Off indicator is not lighted. How can I change the AM to PM time announcement?
This unit does not exist where we are based. The link may work better for you. Add 'manual' to the end of the search query and the maker to the beginning. All questions need 'make model (what it is)' first 3 words. https://www.google.com/search?q=XS2500+answering+system ..
1/11/2024 4:08:37 AM • Lands Phones • Answered on Jan 11, 2024
How to clear up/cancel "1 New Call," "Message Waiting" and reconfigure Call Forwarding on CIDCO Model CT100 ?
This is a very standard wired Desk Phone with Caller ID. It does not have an Answerphone. Your Message Waiting is with your Telco Telephone Service Provider. Phone then and ask the procedure for checking your messages. I doubt this basic phone has Call Forwarding UNLESS is is part of an office system with an Exchange Control Box. As a home phone bought from a secondhand shop, it is very basic. https://www.ebay.com/p/5044703761 ..
1/11/2024 3:15:57 AM • Lands Phones • Answered on Jan 11, 2024
How do I set the
Try this:
DX-80 Time Change Instructions
Software Revision F32 and later
From the attendant station or an phone with attendant password:
1. Press Feature #0 from the telephone dialpad. You will be prompted to enter the Tenant Group
number. This is typically 1, however it can be set for Tenant Group 1-3.
2. Press Save and enter in the attendant password (default is 9999), then press Show.
3. Press the Next option until the display prompts you for the System Time. Press Show.
4. The last 2 digits of the year will be displayed. If you do not need to change the year, press Next. If
you need to change this value, press Chg, enter in two digits for the year and press Save then Next.
5. The current month setting will be displayed. If you do not need to change the month, press Next. If
you need to change this value, press Chg to cycle through the 12 months. When you reach the
appropriate setting, press Next.
6. The display will show the currently programmed day of the month. If you do not need to change the
date, press Next. If you need to change this value, press Chg, enter in two digits for the date and
7. The day of the week (Sat - Sun) will now be displayed. If you do not need to change the day, press
Next. If you need to change this value, press Chg to cycle through the days of the week. When you
reach the appropriate setting, press Next.
8. The current hour will be displayed. Press Chg and enter in two digits for the hour in military format.
Press Save and Next.
9. The display will now show the programmed minutes. If you do not need to change the minutes,
press Next. If you need to change this value, press Chg and enter in two digits for the minutes (01-
59). Press Save then Next.
10. You will be returned to the top level off System Time. To exit Attendant Administration, pres
On/Off button twice.
Software Revision F2x
From any telephone:
1. Press Feature # * and enter in your password. (Default password ########).
2. Press Show and enter 08 14.
3. Press Save then Show.
4. The option to change the Year will appear. If you do not need to change the year, press Next. If
5. The option to change the Month will appear. If you do not need to change the month, press Next. If
you need to change this value, press Chg, enter in two digits for the month and press Save then
Next.
6. The option to change the Day will appear. If you do not need to change the date, press Next. If you
need to change this value, press Chg, enter in two digits for the date and press Save then Next.
Printed in the USA Page 2 of 2
7. The option to change the Weekday will appear. If you do not need to change the weekday, press
Next. If you need to change this value, press Chg, to select the weekday, and press Next.
8. The option to change the Hour will appear. Press Chg and enter in two digits for the hour in
military format. Press Save then Next.
9. The option to change the Minutes will appear. Press Chg and enter in two digits for the minutes and
press Save.
10. Press the On/Off button to take the phone out of programming mode.
1/3/2024 2:10:18 PM • Lands Phones • Answered on Jan 03, 2024
Lands Phones Logo
Popular Tags
9 questions posted
Top Oregon Scientific Lands Phones Experts
k24674
Are you an Oregon Scientific Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Oregon Scientific Lands Phones
Most Popular Question
operating instructions model no ba218
  • Lands Phones
