20 Most Recent KitchenAid KGSK901SSS Gas Range Questions & Answers
Kitchenaid Model KGSK901SSS. This is a brand new stove functioning at 6500 ft. altitude. In the morning, the flame from the burners is primarily orange flame. Later in the day and evening, the flame b
The color of the flame indicates the ratio of fuel to oxygen. There is a change in your environment morning to evening. Do you have a very air tight home? Perhaps over night the oxygen level is diminished. During the day people come and go, opening doors to bring in outside air. Over night the gas heater may be running more. You should get a carbon monoxide alarm monitor and have them check your furnace system vents. The stove might need a vent.
10/4/2017 11:25:49 PM • KitchenAid... • Answered on Oct 04, 2017
Self clean and oven light
The latch is stuck halfway! Take your finger and push the latch all the way to the right until the oven light goes out. Now hold it there and press the self clean button. Let it start up for a few seconds then hit the off/cancel button and let go of the latch. It should hear it made a winding like sound as it goes back to it starting position.
4/12/2014 5:37:01 AM • KitchenAid... • Answered on Apr 12, 2014
When I start the oven, the stove top ignitors
In your model, maybe everything sparks when one item is turned on. That might not be a problem.Two possibilities: The spark board is defective or the gas valve is defective. Each one cost about 150 each. The gas valve is the one that we usually see go first.Ohms out the gas valve: middle wire to wire on the left; middle wire to wire on the right. If the values are not close or one reading shows 'open' then replace the gas valve.
10/20/2013 2:45:58 AM • KitchenAid... • Answered on Oct 20, 2013
0answers
Kitchen aid gas range igniters won't stop
Jammed and broken ignight switch or the spark generator transformer has a short circuit
7/14/2011 12:35:38 AM • KitchenAid... • Answered on Jul 14, 2011
Gas covection oven temperature does
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
1/12/2011 9:32:02 PM • KitchenAid... • Answered on Jan 12, 2011
I have a kitchenaid gas
Sorry to read about your problem, I hope this helps you out.
yes, you can heat them up just a little, or use the cold directions on the spray can..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
12/26/2010 2:28:55 PM • KitchenAid... • Answered on Dec 26, 2010
KitchenAid KGSS907SSS00 Oven. After self cleaning the oven I get error code F3E3 about the meat probe.
Question edited for clarity and add Maker. Question moved to maker category. Number 1 Tip, never ever use the self cleaning feature. It only exists to break the appliance and create the need for parts and service calls. The temperature is just too intense for the parts. A self-cleaning or pyrolytic oven is an oven which uses high temperature (approximately 932 °F (500 °C)) to burn off leftovers from baking, without the use of any chemical agents. The oven can be powered by domestic (non-commercial) electricity or gas.
Why You should Never Run A Self Clean Oven Cycle & ...
General Appliance Service https://www.generalappliancesvc.com > why-you-shou... Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or ... -------------------------------------------------------------------------------------- The only thing suggested is doing a power cycle, but the heat has probably fried the control board which is located too close to the oven and all that heat. https://www.google.com/search?q=KitchenAid+KGSS907SSS00+F3+E3+Error ..
10/5/2023 2:00:27 AM • KitchenAid... • Answered on Oct 05, 2023
KitchenAid Stove KERS205TSS 2 light issues.
The issue with the oven display light and the oven light on the KitchenAid Stove KERS205TSS 2 may be related. The problem with the oven display light could be due to a faulty control board or a malfunctioning light switch. The control board may need to be replaced if it is not sending a continuous signal to keep the light on. On the other hand, if the light switch is defective, it may not be able to maintain a connection to keep the light on. The issue with the oven light staying on could also be due to a faulty light switch. If the switch is stuck in the "on" position, it will not turn off even when the door is closed. This can cause the bulb to burn out prematurely and waste energy. To fix this issue, you may need to replace the light switch. It is possible that both issues are related and caused by a malfunctioning control board. If this is the case, replacing the control board should fix both problems. To fix these issues, it is recommended to contact a certified technician or an authorized service center for KitchenAid appliances. They will have the expertise and tools necessary to diagnose and repair the stove safely and effectively.
6/21/2023 7:50:53 PM • KitchenAid... • Answered on Jun 21, 2023
Gas range will not light. How can I get the oven to light?
The switch that makes it spark?
1/26/2022 5:45:16 PM • KitchenAid... • Answered on Jan 26, 2022
We can not power our Kitchenaid oven off. We unplugged and plugged it back in and got a display of a red 04 on top and in blue underneath AM71 UI71 EEKGO-010. Please advise
We are FIXYA dot com, we aren't Kitchen Aid. You error needs a service call, because it probably needs a new control board. These aren't cheap so it needs professional diagnosis. https://www.google.com/search?q=AM71+UI71+EEKGO-010+error+04 ..
1/18/2022 4:26:39 PM • KitchenAid... • Answered on Jan 18, 2022
KitchenAid KGSK901SSS Gas Range Logo
24 questions posted
Top KitchenAid Kitchen Ranges Experts
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Kitchen Ranges
Most Popular Question
kitchenaid model kgsk901sss brand new
  • Kitchen Ranges
