20 Most Recent Gateway MC7801u Notebook Questions & Answers
My Gateway MC7801u Notebook crashes and goes to a
Your OS software may be corrupted. Did you try reloading the machine with your recovery software? If that does not do it, then the problem may lie with the motherboard or one of your peripherals.
3/21/2017 3:19:07 PM • Gateway MC7801u... • Answered on Mar 21, 2017
P6860 power light flashes no boot
Computer does not boot up The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
3/30/2013 5:15:15 AM • Gateway MC7801u... • Answered on Mar 30, 2013
2answers
What is serial number for mc7801u
Yes! go to www.ebay.com Type make and model of laptop, refine search to keyboard.
5/21/2012 7:28:17 PM • Gateway MC7801u... • Answered on May 21, 2012
2answers
Can anyone give me the serial number for gateway laptop MC7801u?
That is impossible to give that kind of information, you should have a tag number underneath the laptop that is used when computers are serviced.
5/21/2012 7:21:19 PM • Gateway MC7801u... • Answered on May 21, 2012
3answers
Gateway MC7801U laptop with a broken screen
The link below is an illustrated guide for the replacing of an lcd panel on a gateway laptop. It is not the same model, but the practices are generally the same.
http://www.insidemylaptop.com/remove-lcd-screen-from-gateway-mt6704-model-ma7/
4/25/2012 1:10:50 AM • Gateway MC7801u... • Answered on Apr 25, 2012
My web cam is not working can i install another web cam
Yes you can. You can purchase any USB web cam and you should be fine.
3/28/2012 2:14:27 PM • Gateway MC7801u... • Answered on Mar 28, 2012
Gateway MC7801u Windows 7 Bluetooth
u can get the driver frrom he manufactures websites
3/8/2012 7:22:29 PM • Gateway MC7801u... • Answered on Mar 08, 2012
I need a schematic for my gateway mc7801u laptop
Hi Brandon ,Well , you got me on this one , you can try 1 of 2 things , 1st - google your make and model/manual , get the info you can with that ,,,or 2nd , email www.gatway.com and ask for the schematic , and lots of luck with that one .............I think the most info you will be from google ...................Good luck Roy
10/11/2011 9:09:18 PM • Gateway MC7801u... • Answered on Oct 11, 2011
CAN NOT START LAPTOP
eowwwwww...!!!!!!
....i think I got a virus. I was on Firefox when my computer spontaneously shut down.!!!!
When I try to restart it the computer tries to restart but then shuts down again within a few seconds....!!!!! The computer doesn't even have time turn the screen on again before it shuts down. ang skit s ulo!!!!!
8/5/2011 6:09:26 AM • Gateway MC7801u... • Answered on Aug 05, 2011
Bios update mc7801u...from 9911 to
If your laptop thinks it is running off of battery power, phlash will crop up with an error such as yours. Make sure you are running on AC power, and remove the battery before running phlash.
6/16/2011 11:51:40 PM • Gateway MC7801u... • Answered on Jun 16, 2011
The glass is broken on
http://content.gateway.com/www.gateway.com/pdf/8512143_LCD_Disassembly_Gde.pdf
6/8/2011 12:58:31 AM • Gateway MC7801u... • Answered on Jun 08, 2011
2answers
My laptop is a gateway
Some people have successfully reset the charging system with the following procedure:
  1. Shut down the computer
  2. Close the lid
  3. Unplug the AC adapter
  4. Remove the battery
  5. Plug in the AC adapter
  6. Open the lid and turn on the computer
  7. Log in to your user account as usual
  8. Shut down the computer again, and close the lid
  9. Unplug the AC adapter
  10. Put the battery back in
  11. Plug in the AC adapter, open the computer and start up again
The battery should now charge normally. If this process needs to be repeated any time soon, the small clock and parameter backup battery inside may have gone bad. I don't know where that is in this particular model. In some designs, it's accessible from the wireless card or memory compartment; in others it's somewhere under the keyboard.
Charging failure can be the result of a broken cable in AC adapter, often caused by yanking on the cable to unplug it rather than pulling on the plug body. Sometimes the adapter jack gets worn out or the solder connection inside the laptop breaks. In these cases, usually no light comes on when you plug in the adapter or the AC power indicator light is intermittent.
Also, if you have a Sanyo battery pack there are some issues with the battery management firmware. Gateway has a BIOS update to address the problem.
4/15/2011 4:11:57 AM • Gateway MC7801u... • Answered on Apr 15, 2011
2answers
Battery/Charge Problems with my MC7801u Laptop
try draining power first from system, take battery and adapter out then push and hold power button for 1 min. after try powering your computer with adapter only, then try with battery, if same thing, means you have bad battery.
1/6/2011 8:49:24 PM • Gateway MC7801u... • Answered on Jan 06, 2011
I cant get online and
may be your disk drive is gone bad. you just need to try using lens cleaner for disk drive or try replacing it.
and for your cant get online problem. may be ISP is not working or drivers for LAN or wifi are accidently gone. So try checking these thing out.
1/2/2011 5:54:39 PM • Gateway MC7801u... • Answered on Jan 02, 2011
My Gateway Laptop mc7801u battery
Check the output of the chargers voltage. It maybe overloading the battery
12/26/2010 2:58:06 PM • Gateway MC7801u... • Answered on Dec 26, 2010
0answers
Gateway MC7801u Notebook Logo
Popular Tags
34 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
M Gateway
  • M Gateway
Most Popular Question
gateway mc7801u laptop broken screen
  • Computers & Internet
