20 Most Recent
i-mate JasJam Smartphone Questions & Answers
I lost entire soft ware and total blank screen how can i get it back into operation
Your best bet would be to look up on the internet where you can find a replacement software that you can download to your phone to get it running again. This is hard to do if you do not know what you are doing, so I suggest taking it into the store. What has happened, is your phone is gone into "brick" mode, it gets this way by downloading a corrupt file, or downloading apps from the internet. Another way this can happen is when you try to root your phone, and it doesn't work properly. I would consult your phone dealer, they can offer a replacement or fix it for a small cost. I hope this helped!
PUK CODE - PHONE BLOCKED
Yes There is but it is only provided by the network opperators
you will need to contact your provider
When switch on the jasjam mobile there is ablank
You have obviously tried soft reset but have you tried hard reset?
Before you do hard reset you have to do a back up and remove the memory card. You will lose all the data on your Jasjam and the device is reverted to factory settings.
Hard reset is only useful for software related issues.
To do a hard reset
Push 2 SOFT keys and reset at the same time.
soft keys are the keys just under the screen
upper button of answer and end keys
and press reset hole
My I-mate jasam fall down
It is for sure that the RINGER has failed on the phone. Unless the phone is opened up this cannot be confirmed as it can be due to a circuit break/crack or the ringer failure. Sometimes a touch up soldering can help to solve this but attempt only if you are equipped.
How can i connect my
اخي العزيز عندي جهاز اي ميت وكان شغال النت فيه
الان عندي اتصال بس ما في تصفحكل ما افوت على التصفح بيكتبthe address is not valid check address and try again
How can i use gps in my phone
I don't understand what you are asking exactly ... I can tell you, your GPS needs to see the sky to function. If you are trying to locate your home EXACTLY on your GPS, go to the center of your home, on a outside wall, and hold it out a near by window so It can see the sky.
Hi i need imate jasjam
Thanks for visiting FixYa!
Your phone was manufactured by HTC and uses the Windows Mobile Operating Platform. As such there are two programs you can download but which one you need will depend on your computer's operating system.
Download and install Windows Mobile Device Center 6.1 if you run Windows Vista
or Windows 7 on your computer and you want to sync content between your mobile
phone and your computer. Windows Mobile Device Center is only compatible with
Windows Vista and Windows 7.
Download here:
http://support.microsoft.com/kb/931937Microsoft ActiveSync 4.5 is the latest sync software release for Windows Mobile-powered devices. ActiveSync provides a great synchronization experience with Windows®-powered PCs and Microsoft Outlook right out of the box. Note: Microsoft ActiveSync works only with Windows XP SP2 or earlier. Download here:
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=9e641c34-6f7f-404d-a04b-dc09f8141141
