20 Most Recent
Autodesk AutoCAD LT 2009 Full Version for PC Questions & Answers
When I try to open AutoCAD I get the Side-by-side config. error:
I think that now there are no problems with finding some online courses that are aimed at gaining skills in working in AutoCAD. Or there are
many resources with textbooks and everything else that will help you gain these skills or find answers to some difficult issues. If you put in a little effort and look for some solutions, I'm sure that there will be much fewer problems with AutoCad.
I've installed autocad 2010 on
In that case, assuming it's a paid for copy, you need to contact AutoDesk, and they will issue you with a different code to put it. It's possible that someone using a keygen was given the same code, which is why you have this problem.
I have a hp ellitebook
1. Autocad uses a lot of memory. Make sure you the maximum ram installed. You can check the virtual memory if that does not work.
2. Shutting down in the middle of an operation can be that the unit is overheating. Use a cooler, docking station, or stand the book on the side with the laptop lid open about 45 degree angle. Leave it on to see if it shuts down within the same time as when it was laying flat with Autocad running. If it takes longer, the problem may be a fan not cooling properly or allow more cooling during the use of Autocad.
HOW CAN I ACTIVATE MY
The program should have come with an activation code inside the box. Usually you can find the code either on the installation disk, or on the manual. If you are unable to find one then you will have to contact Autodesk support. Once you provide them with proof of purchase they should be able to provide you with the correct activation code.
