20 Most Recent
Broderbund American Greetings Spiritual Expressions 7 Full Version for PC Questions & Answers
Will this version of Spiritual
I have heard that it does work with windows 7 but there are some compatibility issues that could make it function poorly or crash unexpectedly. Unfortunately there isn't much more information about this product with Windows 7.
Need drivers
They are probably protecting their copyright and blocking you from scanning. If you want to spell check, highlight and copy text (if it allows you to) and spell check after pasting into a MS Word doc.
Would the Broderbund American Greetings
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
I have Spiritual Expressions for
You may be able to get it to work by installing it in compatability mode. Right click on the install file and choose windows 98 on the compatability tab.
You could also use a virtual machine, you could load a copy of windows 98 and then use your program in the VM.
There are free Virtual machine programs, but you would need a valid copy of win 98
I have american greetings spiritual
This is a Windows 98 program. Try installing it using the compatibility feature of WIN7. Right click on the startup program on the CD, select install as administrator, right click again and select properties, install as W98 compatible.
This might work but some of these older programs just won't work with Vista or Win7. I didn't find any updated spiritual expressions software. It looks like it is no longer made.
Also you didn't say if you're running 32bit or 64bit Win7. Be aware that 64bit does not support 16bit programs. Given the age of spiritual expressions, it is probably 16bit code. No way will it run on a 64bit OS. My above suggestion will only work with 32bit Win7.
