20 Most Recent
Trend Micro AntiVirus plus AntiSpyware 2008 Questions & Answers
My internet times out all the time
If it is restarting the processes of Trend Micro that you are talking about, click start and go to run. If you are using the 2008 version of TM, type tissuprt. on the first tab, click on start all components. That should start the processes.
Can not update software
Most likely the firewall on you security software is causing the problem. If you know how to disable it open your security software and turn off the firewall. After updating the software, turn on the firewall again.
If you are not able to do the above steps. We will have to disable it from MSCONFIG.
Click start – Run – Type “msconfig” – Hit enter
Click on the Tab “Startup” on the top, Click “Disable All” button
Click on the Tab “Services” on the top, Put a Check on “Hide All Microsoft Service” , Click “Disable All” button
Click OK.
Restart the computer and try updating the software now. It should work. Once updated, open msconfig again and select “Normal Startup” to reset it back to the default settings again.
I forgot my key number and password. How can I retrieve them
Best bet would be to ask assistance from someone with credentials to reset your user account. Otherwise you may try to completely default the device with directions included with unit. This may involve any software that came with it when new.
How to instal antivirus in laptop
Installation on any computer be it a desktop or laptop is a simple task of doing a setup procedure. What ever program you are using, it comes with the setup or start program and this is an automatic install feature.
Disable wireless lan
Hi Bounthavee S,I understand that you want to disable wireless LANIn router : Open Internet ExplorerGo to 192.168.1.1This is home page of routerType the following user name and password when promptedUser name adminPassword adminClick on LAN Settings on the leftside menuRight side, you may find option to disable the Wireless LANClick on Save settings at bottomRouter will reboot and take 3 to 5 minutesCheck if the Wireless LAN is disabled.In one computer : We need to disable the Wireless Adapter Goto Start >> type devmgmt.msc in the search box and press enterThis will take to you Device managerExpand the Network Adapter Right click on 802.11 (wireless adapter) and select disable.This will disable the Wireless LAN only in this computer
My icon disappered want on ondesktop
Do a system restore. Press on start or the windows pearl.Programaccessoriessystem toolssystem restoreSelect a date when your icons were still on your desktop. Launch the restore and it should come back. Let me know if you have any more questions.Thanks~!Carlo
