20 Most Recent
Navarre PC Tools Spyware Doctor W/ Antivirus 2009 V6.0 Questions & Answers
The Spyware Doctor won't update
Contact SPYWARE DOCTOR SUPPORT at
http://www.pctools.com/support/or
you can try any of these:
1:
run checkdisk utility to repair any dumped areas. sometimes you to
electricity failure or some other reason some files get dumped.
you
can run checkdisk utility by pressing WINDOWS LOGO KEY + R and then
enter "chkdsk" in the pop-up window and press ENTER. after that select
the drive on which you have installed that software.
(Note that if
its in the same directory as the operating system you might be required
to Schedule the CHCKDSK on the very next RESTART)
2>Alternatively uninstall the software and then re-install a fresh copy and then try to update
HOPE THAT HELP
REGARDS
Spyware doctor is blocking access to yahoo
http://free.avg.com/ Here is what you need!!! Click on the Above Link. Download Software!!!
uninstall the spyware doctor
install the avg its protect u r computer for spyware and viruses after install avg restart u r computer
Hope This Helps!!! Please Don't Forget to Rate my Response!!! Thanks!!!
yuva
Lost my activation code and
A ticket number is usually assigned to you after you submit an issue or question w/ most companies. If you have not already attempted to contacting them, I would suggest doing so to resolve your problem. If you registered you security software, you should be able to give them your email address and call them for your activation code.
http://www.pctools.com/support/phone/ Try using your email address in the blank field, then call if it works.
DO NOT WANT MY FREEZE DELETE IT NOW
You can use Malwarebyte available free for 60 days.
It will remove all the spys.
You can use kaspersky virus removal tool also.
Thanks
uttam
Activation cose is?
the activation code should be in the box, or on the instructions. if not google "acitivation code for NAVARRE PC TOOL...."
How i can get free untivirus program
avg is free but if you really want your PC protecting buy one or use torrents to get one for free but i am not explaining this as it is illegal but i anti virus programs are overrated if your careful of the sites and things you download yo will be fine without one trust me hope this has been of help
Spryware dr run smart problems
1: run checkdisk utility to repair any dumped areas. sometimes you to electricity failure or some other reason some files get dumped.
you can run checkdisk utility by pressing WINDOWS LOGO KEY + R and then enter "chkdsk" in the pop-up window and press ENTER. after that select the drive on which you have installed that software.
(Note that if its in the same directory as the operating system you might be required to Schedule the CHCKDSK on the very next RESTART)
HOPE THAT HELP
REGARDS
I installed Spyware Doctor and my computer froze
Hi !!
To fixing malware issues & spywares threat. This is the best steps one could follow:
Hi There !!
Thank you for choosing fixya.com
You may experience any one or more of the following symptoms:
-When you start your computer, or when your computer has been idle formany minutes, your - Internet browser opens to display Web siteadvertisements.
- When you use your browser to view Web sites, other instances of your browser open to display Web site advertisements.
- Your Web browser's home page unexpectedly changes.
- Web pages are unexpectedly added to your Favorites folder.
- New toolbars are unexpectedly added to your Web browser.
- You cannot start a program.
- When you click a link in a program, the link does not work.
- Your Web browser suddenly closes or stops responding.
- It takes a much longer time to start or to resume your computer.
- Components of Windows or other programs no longer work.See:
http://support.microsoft.com/kb/827315/en-us
"Unexplained computer behavior may be caused by deceptive software".
1. Run the Microsoft Windows Malicious Software Removal Tool 2. Download ATF Cleaner by Microsoft MVP Atribune from http://www.atribune.org/ - Double-click ATF-Cleaner.exe to run the program. - Click Select All found at the bottom of the list. - Click the Empty Selected button. - Click Exit on the Main menu to close the program. - Shutdown/restart the computer. 3. Next, download Malwarebytes' Anti-Malware to your desktop. [Malwarebytes' Anti-Malware was created by a Microsoft MVP and is free for personal use].- Double-click mbam-setup.exe and follow the prompts to install the program. -At the end, be sure a checkmark is placed next to Update Malwarebytes'Anti-Malware and Launch Malwarebytes' Anti-Malware, then click Finish. - If an update is found, it will download and install the latest version. - Once the program has loaded, select Perform full scan, then click Scan. - When the scan is complete, click OK, then Show Results to view the results. - Be sure that everything is checked, and click Remove Selected. 4. Download, install, update and run: SUPERAntispyware (freeware) - How do I download and install SUPERAntiSpyware?- Customer Service and Product Support (FAQs) 5. If still no joy see and follow carefully:
"Checking for/Help with Spyware, Malware and Hijackware" In the event you need further assistance with malware removal, I suggest you follow the instructions at one of the ASAP Member sites that provides malware removal assistance.
All these tools & software are available free for personnel use.
Hope this would help !Regard'sAnurag Shukla
Registry key for spyware
Dear sir,
please use the following keys
SPYWARE
//3.1
6931-f91f-8fbb-da68-oddd-c5bd-e7e7-fcb7-feo7-4bff
//3.2
Code: B96B-FCBE-F044-1AE0-7363-83A9-DF38-EA1E-F7B5-9D9C
NOTE : DO NOT RUN SMART UPDATES
regards
murali
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
