20 Most Recent
Panasonic KX-T7436 Phone (KXT7436000000) Questions & Answers
Hi I have been tasked with simple programming task
Don't they have Panasonic Engineers where you are? We don't have ISDN here, but we do have things like software revisions, CF off premise, and flags in 990 and 991 that have to be turned on to forward a call to outside numbers. In our features guide, 4.3.13 Call Forwarding -- To Outside Line, there's a Conditions and Programming Guide References that tell us that you need Class of Service changes and Outside-to-Outside Line Call duration time (206 default 10 minutes) 504 CF to outside line and 601 Class of Service programs to change.
Your Mileage(Kilometers) May Vary.
Carl
6/26/2011 1:14:01 PM •
Panasonic...
Answered
on Jun 26, 2011
Panasonic kx t7436 how many conference will do
you can do as many conferences as you have phones, but one phone can have one conference at a time with 3 total parties(depending on your phone system) in the conference (so yourself and 2 other people, inside or outside of the office)
if you have a TDA/TDE/NCP phone system (blue box on the wall or in a computer rack) you can have 5 people in a single conference...
if you have a TD phone system (white box on the wall) you are limited to a 3 party conference
1/7/2011 5:49:13 PM •
Panasonic...
Answered
on Jan 07, 2011
Panasonic KX-T7433 CO Not Assigned Error
The "CO Not Assigned" error on your Panasonic KX-T7433 handset indicates that the Central Office (CO) line has not been properly assigned to the handset. Since you've mentioned that other handsets in your office can connect to CO-01 without any issues, the problem seems to be specific to certain handsets. Here are a few steps you can take to troubleshoot and potentially resolve this issue:
- Restart the Handset: Sometimes, a simple restart can resolve temporary glitches. Try unplugging the handset's power cord for a few seconds and then plugging it back in.
- Check CO Assignment: Double-check the CO assignment settings on the problematic handsets. Make sure that the CO-01 line is correctly assigned to those handsets. Follow these steps:
- Press the "Program" button on the handset.
- Dial 1 (CO Line Access).
- Dial the line number you want to assign (in your case, 01).
- Press the "Auto Dial/Store" button to save the assignment.
- Hang up the handset.
- Reset the Handset: If reassignment doesn't work, you can try resetting the handset to its default settings. Keep in mind that this will erase any customized settings on the handset. To perform a reset:
- Make sure the handset is not in use.
- Press and hold the "Program" button while you reconnect the power cord.
- Keep holding the "Program" button until the handset displays "Initializing..." and then release the button.
- The handset will restart and return to its default settings. You'll need to reconfigure any personalized settings afterward.
- Firmware Update: Check if there are any firmware updates available for the Panasonic KX-T7433 system. Outdated firmware can sometimes cause compatibility issues. Refer to the user manual or Panasonic's official website for instructions on updating the firmware.
- Contact Panasonic Support: If none of the above steps resolve the issue, it might be best to contact Panasonic's customer support. They can provide specific guidance based on your model and system setup.
- Physical Check: Ensure that the physical connections and cables related to the CO-01 line are secure and functioning properly. A loose connection could lead to communication problems.
Keep in mind that these steps are general suggestions and may need to be adjusted based on the specific model of your phone system and any unique configurations in your office. If you're not comfortable performing these steps yourself, it's recommended to seek assistance from a professional technician or the manufacturer's support team.
