20 Most Recent
Seiko SKA098 Wrist Watch Questions & Answers
Where can I find the pictures : how to install the movement
there is some videos on you tube but is a difficult work!is the same with all the watch calibers!you need special tools microscope and experience.in the end if you put everythihg in correct you have to adjust the hairspring to keep the correct time!enother special and expensive timing tool!
The ease of repairing Seiko watches.
No. First off no watchmaker has a "parts account" with Seiko. Seiko
only sells watchbands to watchmakers. All other Seiko parts are sold
through supply houses.
Seiko parts are not hard to find most times. The very old Seikos will
have parts issues and some of the current styles of Japan only Seikos
will not have parts available.
Case tubes for all Seiko watches are not available at all.
Finding parts for Seiko watches requires the use of the watches model number which is on the case back of the watch. The number listed in the title is not a model number. The SKA098 is a retailers number so the retailers can reorder the watch. It does not cross reference for parts.
There are many watchmakers that don't want to service Seiko watches so they can and do make up all kinds of stories as to why it is impossible to repair them and so on.
Actually Seiko is much better about parts supply than any of the Swiss watch companies.
Hope this helps.
Ken
Yellowstone Watch Inc.
Don't store the power long
The internal storage cell is defective, or the velocity generator is not putting out the proper voltage to charge the cell and or the movement needs a very good cleaning and it is bogging down the opertion.
You watch can only be properly serviced by the Seiko authorized center. This is not something you can do yourself unless you have access to the parts, specialized tools, and are experienced at this type of service.
Jerry G.
How can I turn off the alarm on my Seiko quartz alarm
TO CANCEL THE ALARM TIME YOU HAVE SET ;
1.Pull out the crown to the first click, and press and hold button “B” until the alarm hands stop to indicate the current time.
2. Push the crown back in to the normal position.
Reset time on a seiko solar watch
you should be able to set it with the stem if your having trouble it may have to go into seiko the solar watches can be very complicated
