20 Most Recent
Seiko SKX173 Wrist Watch Questions & Answers
15 to 20 minutes fast per day
if your caliber is automatic 7s26b something is wrong with the hair spring try a seiko service center anyway isnt something that you can fix by yourself!beware!far away from jewelers and local battery changers and other monkey magicians!automatic watch calibers are delicate and they ruine them!
How can I turn off the alarm on my Seiko quartz alarm
TO CANCEL THE ALARM TIME YOU HAVE SET ;
1.Pull out the crown to the first click, and press and hold button “B” until the alarm hands stop to indicate the current time.
2. Push the crown back in to the normal position.
Reset time on a seiko solar watch
you should be able to set it with the stem if your having trouble it may have to go into seiko the solar watches can be very complicated
How do I reset the Seiko ch-899
You can follow these steps to reset your watch manually:
- Press and hold "SET" button for 2 seconds until the hour digit.
- Press "ADJUST" button to change the value of the hour digit.
- Press the "SET" button once, the minute digits will flash.
- Press the "SET" button once, the second digits will flash.
- Press the "SET" button, "12H" or "24H" will flash.
