20 Most Recent DIGITECH RP500 Guitar Multi-Effects Pedal Questions & Answers
My Wawa pedal went out on my Digitech RP 500 how could I make it work again
This might work - Hold the bypass switch for five seconds and follow the on screen instructions to calibrate the expression pedal. If that doesn't work you could also try doing a back up and then a factory reset. You may also consider a separate wah pedal. There are many recommendations at: What Is The Best Wah Pedal For The Money Our Answer For You
7/28/2017 11:47:23 PM • DIGITECH RP500... • Answered on Jul 28, 2017
Service manual schematics
If you open up the unit, you may be able to fix the jack if it has come loose and maybe got a broken connection in the process. It may just be a "cold solder joint" causing the problem
9/5/2014 3:05:57 AM • DIGITECH RP500... • Answered on Sep 05, 2014
How does the iPod Nike running monitor work?
The Nike GPS monitor fits into your sneaker and you can track your progress on your iPhone or iPod with a special app. You can download the app from the iTunes app store.
http://nikerunning.nike.com/nikeplus/v1/pdf/English.pdf
11/25/2014 12:13:15 PM • Running • Answered on Nov 25, 2014
Can you put running shoes in the washing machine if they are air?
I have always washed my sneakers in the washing machine, if they have air bubbles make sure that you wash them on a cold wash and not too hot as this can cause the bubble to expand and rupture.
1/13/2013 12:44:04 PM • Running • Answered on Jan 13, 2013
My Nike air max bubble has burst can this be repaired?
It is unlikely that the bubble can be repaired but Nike does have a 2 year warranty depending on the wear and tear of the shoe, you could take them to the store you got them and see what they say.
1/13/2013 12:43:22 PM • Running • Answered on Jan 13, 2013
DIGITECH RP500 Guitar Multi-Effects Pedal Logo
2 questions posted
Top DIGITECH Running Experts
Gloria R. Bloomberg
Gloria R. Bloomberg
Sara Patterson
Sara Patterson
Level 1 Expert
Are you a DIGITECH Running Expert? Answer questions, earn points and help others
View Most Popular
DIGITECH Running
  • DIGITECH Running
Most Popular Question
wawa pedal went out digitech rp 500
  • Running
