20 Most Recent Panasonic KX-T7636W Corded Phone Questions & Answers
Phone diversion wont turn off?
Can't you just contact your systems admin? :) Are you sure you turned off the call forwarding? http://service.us.panasonic.com/OPERMANPDF/KXTVA50.pdf
5/21/2015 6:44:25 AM • Panasonic... • Answered on May 21, 2015
0answers
VIEW CALLER ID
Be the first to answer 1/7/2014 3:16:45 AM • Panasonic... • Posted on Jan 07, 2014Be the first to answer
I have hooked up another panasonic corded phone to
go off-hook then press *391(on the kx-t7636)
10/26/2013 5:09:23 AM • Panasonic... • Answered on Oct 26, 2013
manual
3answers
How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
5/7/2013 10:36:00 PM • Panasonic... • Answered on May 07, 2013
How to assign extention bottons on a KX-T7636
Do you have programming software?I will gladly guide you through.
2/9/2013 10:24:02 PM • Panasonic... • Answered on Feb 09, 2013
I've followed the instructions to
Keep pressing PROG ** until you find the phone that doesn't beep. In a basic TDA system, it's the first extension (101) that is the default master phone.
Carl
9/21/2011 11:27:06 AM • Panasonic... • Answered on Sep 21, 2011
I want to zero lock
Unless you're familiar with the Features Guide for your TDA system, you're probably better off calling your Panasonic dealer. It involves Toll Restriction (TRS), Class of Service (COS) and installer programming access. In our installations, we have a customer that makes International calls via Vonage and local calls on local lines. For that feature, we turned on Automatic Route Selection (ARS) so the user just dials 9 and the number and the dialing plan sorts it out by the rules applied in the tables. ARS takes a very long time to program.
Don't shoot the messenger, me, by expecting a step-by-step answer in a free forum. Toll restriction would take me about 30 minutes to set up if I even knew your numbering plan. If you build it in less than an hour, consider yourself lucky.
Carl
12/27/2010 4:36:26 PM • Panasonic... • Answered on Dec 27, 2010
I want to change the user's name on the display
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
3/28/2010 6:09:38 AM • Panasonic... • Answered on Mar 28, 2010
2answers
Phone forwards to voice mail in 2 rings !!!
Have you found a solution for this?
1/27/2010 5:05:34 PM • Panasonic... • Answered on Jan 27, 2010
My panasonic kx-t7636 phone has caller id. however
you need to go to the call settings on phone and adjust the call waiting there ok
7/20/2009 8:15:53 PM • Panasonic... • Answered on Jul 20, 2009
2answers
CHANGING THE TIME ON PHONE
I can give you the fast answer and the slow answer. Fast one is to go to the main phone, press PROG and dial **1234. The system should go into programming and you will be looking at system program 000. ENTER. From there, using a combination of the SEL, FWD and CONF keys, you should be able to navigate around the time change, using ENTER or STORE to save it.
The arder way is to grab the manual here http://www.public.carl.airpost.net/TDA/TDA_PTPM_32.pdf and start reading it from page 12 then follow the instructions on page 16.
Keep in mind that TDA programming is usually done from the master phone, or any phone assigned programming status. It may be all or NONE.
Carl
4/16/2009 12:30:24 AM • Panasonic... • Answered on Apr 16, 2009
My kxt 7636 dispqy the
There's a message. It may not be voice mail. Press the MESSAGE button and read the display. You also can CLEAR it by the soft key under the display.
Carl
4/15/2009 11:06:50 AM • Panasonic... • Answered on Apr 15, 2009
2answers
How do u get your Panasonic house phone working model number is kxtga850e keeps saying no link to base reconnect main base ac adaptor
It sounds like the phone system base station is burned out.
2/3/2024 8:19:25 AM • Panasonic Lands... • Answered on Feb 03, 2024
My phone is always on MUTE. How do I turn that off?
Press the mute button to turn mute off.
12/27/2023 5:21:29 PM • Panasonic Lands... • Answered on Dec 27, 2023
How i can change panasonic kx ts500mxw ring tone
I don't think that is possible on that model of phone. This is a phone with only the basic features and a fixed ringtone.
12/21/2023 9:33:34 AM • Panasonic Lands... • Answered on Dec 21, 2023
Panasonic KX-FLB 852 Call Service 6 problem
See Section 6 (Troubleshooting) Section of Service Manual and Page 118 for remedial action. Troubleshooting Guide; User Recoverable Errors - Panasonic KX-FLB852CX Service Manual [Page 81] ' ManualsLib
11/3/2023 10:16:44 AM • Panasonic Lands... • Answered on Nov 03, 2023
Panasonic KX-T7636W Corded Phone Logo
26 questions posted
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
names extention numbers panasonic kx
  • Lands Phones
