20 Most Recent
Chicco 4-in-1 Quattro Ride On Car Questions & Answers
I cannot get the green seat off of the Chicco 4
i would put it in your car and let it get warm, then try..you know with the heat in the summer with the doors and windows closed it will be more able to give and it might budge! Good luck..it's a physics thing!
How do i order parts for 4 in 1 ride on car?
this is a link below
log-on to this link, fill in the part you want to replace, and search for it,
when it opens, enter your ZIP CODE and you will be located and you will receive an address on where to buy
http://babies-kids.pricegrabber.com/play-centers-walker/Chicco-4-1-Quattro-Ride-Car/m701566432.html
I TOOK CHICCO CAR SEAT
Good day!!!!
Installing your Chicco KeyFit car seat correctly is essential in keeping
your infant safe. You can use the Chicco KeyFit car seat for children
from 4 pounds to 30 pounds. You can install the car seat in your vehicle
using one of two options.
Instructions
Vehicle Belt
Park your vehicle on a level surface to ensure the car seat is installed in a level position.
Store the LATCH connectors if
you use a seat belt to secure the car seat. LATCH is a child restraint
attachment system that comes in a number of cars manufactured after
Sept. 1, 2002. Lift up on the LATCH release lever and pull the LATCH
connectors out of their storage pockets. Insert the LATCH connectors
into the storage pockets, pull the LATCH strap to secure them, and then
roll up the pull strap and tuck it in the storage pocket.
Place the base of the Chicco
KeyFit car seat in a forward facing vehicle seat with the recline foot
against the back of the seat.
Push the recline buttons on each
side of the base while lifting the base to adjust the base angle. The
base is positioned correctly when the bubble is between the arrows on
the recline indicator on the side of the base.
5
Insert the vehicle belt through one opening in the base, across the base and out the other opening.
6
Push the base firmly down and pull on the vehicle belt to tighten the belt.
7
Slide the vehicle shoulder belt
into the shoulder belt lock-off on the side of the base. You should put
the belt only in the shoulder lock-off on the opposite side of where the
seat belt buckles.
8
Check to make sure the seat belt is tight, the base is stable and the bubble on the recline indicator is between the arrows.
9
Line up the carrier with the
base and push the carrier firmly into the base. You should hear a click
when it is secure, but pull up on the carrier to make sure it is
latched.
LATCH
Park your vehicle on a level surface for proper installation.
Lift the LATCH release lever and remove the LATCH connectors from their storage pockets.
Place the base in a forward
facing vehicle seat with the recline foot against the back of the seat.
Follow Step 4 in Section 1 to set the angle of the base.
Push the LATCH connectors firmly
onto the LATCH anchor bar in your vehicle. You should hear a click when
they are attached, but you can make sure they are secure by pulling on
the straps. The Chicco KeyFit car seat is designed for use with lower
LATCH anchors that are 11 inches apart. Verify the spacing in your
vehicle in your owner's manual.
5
Press the base of the car seat
down and pull up on the LATCH pull strap to tighten the LATCH belts.
Tuck the pull strap into its storage pocket and attach the carrier.
And you can view this manual to see the actual installation with picture:
http://www.juststrollers.com/images/pdf2/CIU032.pdf
Hope it helps..
Thanks for using fixya...
9/24/2011 4:42:43 PM •
Chicco Toys
Answered
on Sep 24, 2011
I have lost the strap
You may order replacement parts by contacting Customer Service at 1-877-424-4226. Parts like this are usually only available through the manufacturer.
5/12/2011 12:15:13 AM •
Chicco Toys
Answered
on May 12, 2011
