20 Most Recent
Graco Pack 'n Play Questions & Answers
Problems re opening the Graco Pack N Play - one side won't lock
if so try always from turnig and pulling up the center and then with some help squeeze pulling up the side of each pack. then try to push everything down.
it's treaky and coming back blocked very fast. you have to manage all of them at the same time
Good luck
Pls let me know if I helped
How do i get the sides to lock/ stay up on my
I think the problem is the way that the safety feature prevents the locking mechanism from moving while the bottom is flat Be sure that the bottom is raised about half way and the rails should lock (or unlock) for you. Hope that helps. wdeblancjr@aolcom
We were able to disassemble our graco playpen but
the locks pull underneath and unblock from each sied of the sides but first turn and pull the center of it if you can't unblock them.
it's treaky and coming back blocked very fast. you have handle all of them at the same time.
Good luck.
