20 Most Recent
Oreck VersaVac Bagless Vacuum / Steam Mop Questions & Answers
Steam mop is not working, even after replacing the filter. Only used three times.
Rejoice with me! I called the helpline and they told me to unplug, then stick a needle into the hole on the bottom where the steam comes through. I did that, then plugged in and turned on the steam. Black liquid came out and a little steam came out. I shut off the machine, unplugged and used the needle again. This time, a geyser of steam went up into the air from the machine! It was clogged and just needed a couple of pokes. I put the steam plate back on and just cleaned my kitchen!
No suction
Take apart. Run all hosing through high pressure water or air compressor.
Oreck xl won't start
This could be for various reasons. Check the power cord and try a different outlet first. See if the power cord is loose or damaged. Next check the brushroll and belt that those are in working order. If you smelt burning or electrical fire or your vacuum made an odd noise before stopping it may be the motor going bad. If your power cord is good and the brushroll and belt good, it is probably your motor going bad.
Replacement Oreck Vacuum Cleaner Motor
GoodVac
800-775-6586
I have Oreck Magnesium and the plastic blue clip broke and bag comes off bc clip broke how do I put on replacement clip
If the plastic blue clip on your Oreck Magnesium vacuum cleaner has broken, you will need to replace it to keep the bag securely attached to the vacuum. Here are the steps to replace the clip:
- Locate the broken clip. It is usually located on the underside of the vacuum, near the bag opening.
- Remove the broken clip by gently prying it off with a flat-head screwdriver or a similar tool. Be careful not to damage the surrounding area.
- Obtain a replacement clip. You may be able to purchase a replacement clip from an Oreck dealer or online retailer.
- Attach the replacement clip to the vacuum. The clip should snap into place and hold the bag securely.
- Test the clip to make sure it is properly attached and holding the bag securely.
