20 Most Recent
Panasonic KX TG5100M Cordless Phone Questions & Answers
Panasonic Kx-TG2432 Displays E9
Same here on KX-TG2248:
"Answer on" is flashing rapidly.
"Message/Slow Talk" is flashing rapidly.
"In Use/Charge" is flashing irregularly.
LED displays "E3" (and "set clock" symbol is flashing).
Removing and restoring power, many times,
produced one "spontaneous remission"
(it worked fine for several hours)
but next time moved (having to disconnect power),
it's now quite "committed" to remaining "insane" as above.
System Error #3
I'm having the exact same problem.
I unplugged the power and plug back in after a min and still no change.
How can can decrease ring volume
To decrease the ringer volume, kindly refer to the detailed instructions in the attached image:
Hope this solves your problem. For more help and clarifications, please feel free to reply to this post.
Thanks for using
FixYa.
Need to delete old voice message
Erasing Messages
The unit will announce the remaining recording time after playback, if it is less than
5 minutes. New messages cannot be recorded when:
— “Memory full” is heard.
— “ ” is displayed on the base unit.
— ANSWER ON indicator flashes rapidly (only when the Answering System is on).
Erase some, or all, of the messages in a mailbox. We recommend you erase unnecessary messages after each playback.
Erasing a specific message
Press [ERASE] while the message you want to erase is being played.
• A short beep will sound and the unit will continue to play the next message.
Press [ ][4] while the message you want to erase is being played.
Erasing all messages in the mailbox
1. Press the soft key ( ).
2. Press the soft key ( , or ).
• If Mailbox 2 or 3 has a password, enter it (p. 51).
3. Press [ ][5] to erase all messages in the mailbox.
• A long beep will sound and “Mailbox (No.)” and “No messages” will be heard.
• To end remote operation, press [OFF].
I hope you rate this solution. Thank you and goodluck!
