20 Most Recent
Exceed-RC 1/10 Drift-Star RTR Radio Remote Controlled Electric On-Road Drif Questions & Answers
Exceed Rc 2.4 Ghz WarHawk
In order to get at the main rotor gears, you'll have to remove both sets of rotor blades and drop the chassis. After removing the battery cage you should be able to access the two main gears. You don't need to remove the motors, but if you need to access the main gear for the lower-rotor, further dis-assembly is required. I think there's a link to a dis-assembly video for the Exceed models on rcdiscuss
I own a exeed RC
The transmission drives the front and rear wheels, so the only thing that could affect the reverse drive would be a bad reverse electrical feed to the motor (since the control board has to reverse the feed to get the reverse action). Not sure what component they use in the ESC, but if it's a relay, the contacts could be dirty. Otherwise, I guess it could be some tricky gear problem in the transmission, although I can't really visualize how that could happen.
I guess the only other control variable is the radio controller, and maybe the reverse coding is messing up, not engaging the receiver in the crawler enough.
You could run it by a Hobby Shop and see if they've seen this problem before, can test it with a demo conroller.
Good luck, and hope this helps.
My son has a Forza
The piston movement draws the fuel into the engine. Is this a new RC? Are you running this RC in the high temps the US has been having lately?
Remote control wont turn on
Hi
Please try to remove the battery and check with different batteries.
Check wen you press any button the RED light is blinking or not ?
I have an Exceed FPV
Well, I have searched the resources I have for anything on this camera and everything I find indicates it is some sort of camera designed to be put in an RC type vehicle. Now, since your post indicates otherwise I will approach this from the Programmers perspective. If there is supposed to be a text file in the root directory to use to set the date/time on the device you should be able to plug the device into the USB port on your computer and see that file using Explorer if you have windows. If the file exist it will be visible if you do this. You should be able to open that file with Notepad and see the entries that are entered. These are most likely 1 entry per line. If this is the case find the one for the date and use the same format to enter the correct date. This is normally DD/MM/YYYY format and the time entry will most likely be HH:MM:SS (Hours, Minutes, Seconds Regular format of time not military time) The name of this file could be almost anything but if you start note pad and then select open from the FILE menu it should only show you files with the .txt extension which should help you identify it. If you open the wrong file simply close it without saving and no changes will take place. Hope this helps.
Will not initiate
Hi
Please be more precise to your problem.Fixya will be happy to helpyou..
Thanks for contacting fixya.com
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part:
1. Contact the Manufacturer:
- Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod.
- Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component.
2. Check for Spare Parts:
- Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components.
- Look for any contact information provided for customer support or spare parts inquiries.
3. Online Search:
- Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase.
- Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture.
4. Local Retailers:
- Visit local baby product stores or furniture stores that carry nursery items.
- Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component.
5. Custom Fabrication:
- If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib.
- Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM •
Toys
Answered
on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
- Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
- Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
- Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
- Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
- Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM •
Toys
Answered
on Mar 21, 2024
