20 Most Recent Electric Novatech High Speed Brushless 70A ESC for Electric Cars Questions & Answers
Hi I bought a stroller
For lipo you need a specific charger and you can use lipo two cells dont go on three cells you push it to hard.
10/18/2017 10:41:04 AM • Electric... • Answered on Oct 18, 2017
0answers
Green ESC light turns red and loses conection
usually thats a low voltage batt thing, I used to laugh when my buddies battery went low, and it resulted in loss of control of his car, (they always ran out of juice before mine) and he would have to chase it down, cuz it would still be rolling around just fast enough he had a hard time getting to it, lol
3/23/2013 9:10:28 PM • Electric... • Answered on Mar 23, 2013
0answers
0answers
0answers
0answers
Novatech High Speed HSP Brushless 70A ESC for Cars, Buggi: wont reach top speed...
The green light wont go solid. .right? so not full speed
Its something wrong with the remote controller, not giving the full speed signal . either change both Tx - Rx crystals . or change the remote. .
but before that try to trim the throuttle on your Rx
8/6/2010 4:52:12 AM • Electric... • Answered on Aug 06, 2010
Hsp bruchless
Hi there
I have the same electronics on hsp rally monster pro. 3300kv - but 75A ESC, i upgrade it to 6000kv with 5000A lipo without any programing to the ESC . it worked fine for couple of runs but i faced wires over heating problems after that something wrong went to the ESC !!! . .
Am going back to 3300kv, but need advice of what is the higher ampers/voltage battery can i use?
8/6/2010 4:23:13 AM • Electric... • Answered on Aug 06, 2010
Hi, i buy this product and i dont know to how to
have u tried ligithin it up
7/15/2010 1:43:52 AM • Electric... • Answered on Jul 15, 2010
Led 1 is solid green
The leds are okay.
Flashing red is Life ASAP.
Good luck.
2/20/2010 11:01:37 PM • Electric... • Answered on Feb 20, 2010
How do you get access to the batteries on a Boreem Jia electric scooter.
Know this is an old post but if someone else needs to know how to get to the batteries on boreem jia remove the nuts at the bottom of the shaft holding the seat where it connects to the fiber glass frame and then remove seat and shaft and then four nuts "2 on each side" under the feet rest, you may need locate the tops under the boreem label by peeling it back to hold while untighting that's it, now you can slide the housing to the side be careful of your wiring only enough room to access and remove batteries. You will have to either cut or use soldering gun to free up the wires hope it helps
6/12/2020 6:48:00 PM • Electric Toys • Answered on Jun 12, 2020
I plug my razor charger to my electric scooter and the charger blinks from green to red what does this mean
Usually means bad batteries or possibly a short.
5/12/2019 9:29:13 PM • Electric Toys • Answered on May 12, 2019
tip
Troubleshooting and Fixing Model Trains That Won't Run
If your train won't run at all, the first challenge is to find what is wrong. If the problem only started after you made recent changes to the track or trains, start there first. If you have no idea where to begin, the six steps below will walk you through the most typical problem areas. Some problems are easy to solve. If you have a broken locomotive or power supply,
Your engine gets its power through the wheels. Make sure all of the locomotives' wheels are on the track by sliding it back and forth gently. Try moving the engine to a different part of the track to rule out a loose rail joint or electrical connection. Start with the connection between the wires and the track, then the connections between the wires and the power supply . Make sure nothing is loose and the wires don't touch. Make sure the wires are connected to the terminals for the track and not accessories. Inspect the wires themselves to make sure they are not frayed or split. Check the electrical plug and socket, too. Is the outlet turned on? If you're setting up for the first time, you can probably skip this step entirely. Dirty track and wheels usually result in rough stop-and-go running, not a complete loss in power. If you've had the trains put away for a long time, especially in a damp environment, you could have corrosion or dirt build-up heavy enough to prevent operation altogether. If you do notice heavy dirt or corrosion, it can usually be removed with some special abrasive cleaning blocks and liquid cleaners It's important to be sure that the power supply is working. The surest way is to use an ammeter to read the electric current. If you don't have an ammeter, a simple test tool can be made with a low voltage light bulb and two short pieces of wire. If you don't detect any current at the supply outputs, disconnect the wires to the track and test again. If you get a light, then you probably have a short in the track or wires. If not, then the problem may be a faulty power supply. If everything checked out at the power supply, retrace the wires to the track again and test here. The ammeter will work, or if you have a second locomotive or even a lighted passenger car or caboose, try putting it on the track. If you are getting good results with this test, the problem is probably in the locomotive itself. If you are just starting out, your best option is to return the locomotive or find a local service location If you have detected a short circuit in the track, check your wires again. A short circuit can occur any time one rail or wire touches the opposite rail or wire. If you have more than one set of power leads, make sure they aren't crossed. It is a good idea to color code your wires. If you are using the 2-rail track, make sure you haven't created a short in a reversing loop or wye . Switches and crossings can also cause a short if the opposite rails touch without an insulated break Don Derail Troubleshooting Model Train Problems
on Dec 14, 2017 • Toys
LOOKING FOR PARTS FOR HOLIDAY EXPRESS ELECTRIC TRAINSET NEED ENGINE,&TREE TOP TENDER
hi brian. i have had a look around the internet but can not find anything at mo.so maybe you could try the likes of ebay.
11/3/2017 2:12:25 AM • Electric Toys • Answered on Nov 03, 2017
Electric Novatech High Speed Brushless 70A ESC for Electric Cars Logo
21 questions posted
Top Electric Toys Experts
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Electric Toy Expert? Answer questions, earn points and help others
View Most Popular
Electric Toys
  • Electric Toys
Most Popular Question
green esc light turns red loses
  • Toys
