20 Most Recent Panasonic KX-TGA520M Cordless Expansion Handset Questions & Answers
0answers
Display fading
Be the first to answer 10/21/2017 4:27:03 AM • Panasonic... • Posted on Oct 21, 2017Be the first to answer
Caller ID setup on cordless phone panasonic kx-tga520m
I would call your phone service provider and have them reset your caller id service.
7/22/2014 11:35:58 PM • Panasonic... • Answered on Jul 22, 2014
0answers
System is busy please try again
please remove battery and wait a while and then insert again. reinitialize and try. hope this helps.
regards
3/12/2011 10:33:55 PM • Panasonic... • Answered on Mar 12, 2011
0answers
My Panasonic KX-TGA520M expansion handset
Yes,it's the battery.Ours does the same thing.Let it charge all day,5 minute phone call,call gets cut off.Being a 5.8 GHz,you may be able to find battery(ies) for it.Mine is older and batteries are discontinued(2.8GHz).Make sure it is rated the same,3.6V,600mAh,or whatever yours is,that is just a sample.Also,it should still be NiMH.Nickel-metal hydride.The packaging wil list the brand names it is for but the numbers definitely need to match 100% or it could cause more serious problems such as battery leaking from wrong rating.The newer technology is DECT 6.0 which was adopted from Europe technology.It is supposed to have better range away from the base,clearer sound,maybe a couple other minor things but I have my doubts as seen on trouble forums and sites such as this one.For one,they work at 1.9 GHz,which will give better range anyway because of the lower frequency used.1.9 GHz is about equivelant to trying to bend a 1/4" steel pipe around a corner while 5.8GHz is like trying to bend a 3/4" piece of pipe around a corner.The 1.9 signal has more "bend" allowed in literal terms.That's the best way I can explain it.Anyhow,I am waiting for a really good sale on phones for holidays to give it a try.Just unwilling to pay full price on a similar technology that was typical of all phones 10 years ago.If you do find batteries,I was going to say maybe buy 2 for each handset,but batteries do not do well sitting around for 5 years.They COULD leak and be worthless by then,unsure but never know.There are many factors to storing them so that they will last.They will be unavailable by then so we can't win for losing.Something like that.Good luck,Greg Also,if you ever get battery acid on you or anywhere you don't want,put baking soda on it ASAP.Baking soda neutralizes acid.Cover in about 1/4" thick layer.
11/17/2010 5:32:57 AM • Panasonic... • Answered on Nov 17, 2010
Unable to hear on my side of the phone
check the mute button
6/14/2010 2:23:54 AM • Panasonic... • Answered on Jun 14, 2010
Screen does not show anything
There seems to be a problem with your display screen or the connection might be loose. You phone care be repaired from any Panasonic or electronic shop as the problem is not that big. The screen display might need to be changed or the repair person will fix the internal connections because of which also the display might not be there.
5/28/2010 1:46:57 AM • Panasonic... • Answered on May 28, 2010
I've lost the manual for this phone. I need
You can download the complete user manual which has the detailed instructions by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view this manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
3/27/2010 10:43:34 AM • Panasonic... • Answered on Mar 27, 2010
Can you just tell me how to change the phone from
1) press the button
2) use the up or down arrow on the button and scroll to "initial setting"
3) press "select" using the button above the button
4) "set answering" should be displayed, if not use the up or down arrows on the button to select
5) "number of rings" should be displayed, if not use the up or down arrows on the button to select
6) use the up or down arrows on the button to select the desired number of rings
7) press "save" using the button above the button
2/15/2010 11:12:54 PM • Panasonic... • Answered on Feb 15, 2010
My panasonic kx-tga520m cordless handset does not
Because your phone was low on battery, you will not see this feature. Once you charge your phone fully, you will start receive phone calls and you will see this feature activating again.
1/20/2010 11:28:32 PM • Panasonic... • Answered on Jan 20, 2010
My phone will just go dead with no notice.
This sounds like you need to replace the battery in both hand sets. You can also get the user manual here if you have lost the one that came with your phone: http://service.us.panasonic.com/OPERMANPDF/KXTGA520.PDF
8/28/2009 12:13:56 PM • Panasonic... • Answered on Aug 28, 2009
How do you take it apart?
http://www.barclaytel.com/install-permapad.wmv
Me too, but I was lucky. I found this video and fixed my keypad in about 3 minutes! Too frickin' easy!
10/30/2007 8:46:02 PM • Panasonic... • Answered on Oct 30, 2007
2answers
How do u get your Panasonic house phone working model number is kxtga850e keeps saying no link to base reconnect main base ac adaptor
It sounds like the phone system base station is burned out.
2/3/2024 8:19:25 AM • Panasonic Lands... • Answered on Feb 03, 2024
Panasonic KX-TGA520M Cordless Expansion Handset Logo
Popular Tags
31 questions posted
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
screen not show anything
  • Lands Phones
