20 Most Recent
AVENUES The SPYDER SwissGear Wireless Laser Mobile Mouse Questions & Answers
Swissgear spyder mouse will not work
Had the same problem with my wife's...you have to push the connect buttons on both the receiver and the mouse almost simultaneously after turning the mouse off and back on. Keep trying, it took me lots of tries.
How do i reactivate the mouse on a new laptop?
hello vmac0313
- Go to your control panel in your laptop and go to mouse settings
- Then go to mouse settings it contains different options go to hardware and click the name of the mouse were present in such a dialog box click that ..
- and then go to properties in that there should "change setting" icon is present click that and change the setting to de-activate the device..
I have changed the batteris, the mouse shows low
hi r_sreedasyam
before your mouse run out of battery, it can still be used?
if it can still be used, try to open the battery cover. positive and negative metal rubbing with sandpaper or any tespen.
re-insert the battery.
(Insert really new)
please call again for more information
thanks and regards
Mouse was working and then it just got stuck..
The problem is not the mouse itself... it is probably the USB receiver. Most likely there is a loose connection. try removing the device, then re-inserting it you may have to jiggle it around a bit, but ultimately I would consider replacing the mouse they are not to expensive $20-50
Spyder won't respond
try cleaning the laser of the mouse. the light spot at the bottom it mite have some dirt or something on it thats not alowing it to have a good conection
I lost the connection between my mouse and the
Try reseting the usb connection. The computer will rediscover the usb "device" and may find it again. Then try pressing the resync button which is probably on the usb dongle. If this doesn't work, press control alt delete. This will bring up your security or process control prompt (depending on how it's set up). If nothing happens after pressing control alt delete, your computer may have frozen (requiring you to cycle power on the computer). If it comes up, use your tab key to cycle through the buttons to the "shutdown" or "restart" button. Once you've reset, you should have your mouse again.
Hope this helps,
Bill
Spyder mouse won't work
I had a similar problem. I corrected by performing a manual connect as listed in the manual that came with the mouse.
Manual reconnect:
1. Plug in the receiver.
2. Turn on the mouse.
3. Press the button on the receiver.
4. Press the connect button on the mouse once within five seconds of pressing the button on the receiver.
This worked for me, and the mouse has worked fine since.
If this doesn't work. The manual suggested taking the batteries out of the mouse for 20 seconds and unplugging the receiver, then repeat the steps above.
If that doesn't work. reboot the computer and repeat the steps above.
Hope this helps.
My red swissgear mouse will not connect to my laptop
I have used allot of different wireless plug and play devices but this by far is the crappiest one by far I am no slouch when it comes to troubleshooting things on my PC but this mouse is junk Problems from day one. My advice is return it before it's too late and buy a different brand. I like the page forward and back right ast my finger tips but the connectivity issues are not worth the hassel
Spyder muse problem
Good batteries? maybe the signal in the mouse has died or been fried, or you could of had a wet hand when you used it and it could of messed up the laser or something, i dont know the solution but i tried to help
My swissgear, red, remote mouse won't work
Try to put a new battery in it's compartment and simultaneously press the reset small button in the bottom of mouse. Both actions mus be performed at the same time. Hope this might solve your problem.
Chawah.
How to Install YouTube DL.py to Download YouTube Videos to my PC?
Actually, you just need the help of a YouTube Downloader. If you still need help, why not try this YouTube/Video Downloader?
Leawo YouTube Downloader acts far more than a single online video downloader to download YouTube videos and other online videos from various video sharing sites like Facebook, Dailymotion, AOL, iFilm, Myspace, Dailymotion, etc. Besides the ability to download online flash videos, this FLV downloader could also acts as video download accelerator to speed up online video downloading, video accelerator to speed up video buffering for smooth playback, video player to play back videos, and IE browser to browse online videos for free downloading. It could extract audios out of online videos, like converting YouTube video to MP3.
Hope it can be another choice for you or other users. :)
Watch online videos offline freely with Leawo YouTube Downloader
What is digital marketing?
Digital marketing, or “online marketing,” is a form of advertising that uses the internet and digital technologies to connect with customers. Digital marketing seeks to accomplish the same thing as traditional marketing except by leveraging computers, smartphones, and other digital devices rather than traditional media, such as print, radio, or television.
