20 Most Recent
Buck Pontiac G6 2005-2007 05 Stereo/radio Wire Harness Plug Questions & Answers
Where can i find the rheostat resistor on a G6
Are you shure it has to do with the resistor, All the resistor does is controls,The different fan speeds, If you are geting no power to it, Have you check if the fuse blew for it? Or the relay for it could be defective, Or the blower motor might be burn,t out,
My g6 2007 does not have the original stereo
I would call all of the salvage yards until you are able to locate one where they have your car. Best to start as close to home as possible because you are likely going to have to go and pull it off. The Dallas County Auto Salvage yard on MacArthur will pull it for you, all you got to do is pick it up. They may mail it. I am not for sure about the mail thing though.
Pontiac G6 please help
newer cars come with an amp built in so mak esure u hook up the amp wire it may end up plugging into the power ant. or amp wire
2007 Pontiac G6 rem wire
This factory stereo does not provide a switched 12 volt source. You will have to go to an accessory power source in the vehicle. That's what the extended red wire is for.
Replaced the bat in 2007 g6 now the radio will not
If it is a factory radio,whenever you remove the battery the radio goes into a locked mode.You need to call a Buick dealer to get the unlock code and have them tell you how to do it.Write down the code for the future possibilities too.Good luck! Greg
Radio wont shut off
The power and ignition wires are crossed there are 2 wires that are important one is a memory wire this keeps your presets and the clocked stored this should have power on it at all times, sometimes the wire color is yellow blue, but never red. And then there the second wire this is only powered when the key gets turned this wire is red always red. My advice to you would be see what wire on the back of your radio is getting power all the time and switch it with the wire that only has power with the key on good luck
No sounds from stereo
sounds like that is the problem i think that you need a special harness go to this website: metraonline.com and look up your vehicle you should be able to find the harness at bestbuy or a car stereo shop not sure how much it could be. May be expensive.....
