20 Most Recent Buck Ford Econline Van 1998-2006 Stereo Radio Wiring Harness Questions & Answers
You need to input the radio theft deterrent code.
Buck Ford... | Answered on May 09, 2017
Useualt Same one as PARK Lights
Buck Ford... | Answered on Mar 02, 2014
Recently purchased this decode software for my business
and it seems to be doing very well. I ran your serial number and received a code of 0102. Would be grateful if you would let me know either way if this code worked as I want to keep track and make sure I got my money's worth buying this software. You can reply/comment here or email me directly at csautomotivecars@att.net.
Thanks and I hope this works for you....
Buck Ford... | Answered on Jun 12, 2013
M023855 code is 3495
Buck Ford... | Answered on Jan 25, 2013
I purchased this radio decode software for my business and it seems to be doing good. I ran the serial number you gave and came up with a code of 7199. Was wondering if you could let me know either way by replying here or email me directly at csautomotivecars@att.net if it worked or not. Want to kind of see how this software is doind as it wasn't really cheap. Hope it works for you
Buck Ford... | Answered on Jan 12, 2013
If you want to remove a stock radio from a 2009 ford E150,then all that you need to do is - Step 1: Use the DTRT in a gentletwisting motion to remove the four (4) retainer clips securing kick panel belowthe steering column. Step 2: Again, place the DTRT inbetween the dash molding and the instrument/radio bezel (the bezel is onecomplete piece that includes the instrument cluster as well as the radio andclimate control) and gently twist the tool around the bezel releasing a seriesof retainer clips. Step 3: Pull the bezel out just farenough to gain access to the two 7mm bolts securing each side of the radio. Now as you open those bolts you canremove the radio.
Buck Ford... | Answered on Jun 29, 2011
1999 Ford Ranger Pickup Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Light Green
Car Radio Switched 12V+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger N/A
Car Radio Amp Trigger Wire: Blue
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): Dark Green/Orange
Right Front Speaker Wire (-): White/Light Green
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
pls rate
Buck Ford... | Answered on Aug 24, 2010
http://www.installdr.com/Harnesses/Ford-Wiring.pdf
this should be the right one for you
Buck Ford... | Answered on Aug 12, 2010
Remove the radio from the dashboard.
Then post the SERIAL NUMBER found on a label on the casing
It normally begins with M ++++++
Buck Ford... | Answered on May 27, 2010
post the serial number found on a label on the radio casing.
it usually begins with M xxxxxx
Buck Ford... | Answered on May 08, 2010
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
Buck Ford... | Answered on Apr 18, 2010
needs bulbs replaced behind front panel of radio very common problem
Buck Ford... | Answered on Mar 17, 2010
online thank you
Buck Ford... | Answered on Feb 07, 2010
Buck Ford Econline Van 1998-2006 Stereo Radio Wiring Harness Logo
34 questions posted
Top Buck Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
handygirl911
handygirl911
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Buck Car Audio & Video
Most Popular Question
key code ford 6006e eon cd rds player
  • Car Audio & Video
