20 Most Recent Buck Ford F250 F350 2002 02 Radio/stereo Wire/wiring Harness Questions & Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing
Buck Ford F250... | Answered on Aug 21, 2010
Remove radio from the dashboard and post the SERIAL NUMBER
Buck Ford F250... | Answered on Aug 06, 2010
Did you happen to look into buying a wire harness adapter? The sell them fairly cheap at Auto Parts Stores. (approx. $20-$25) It is very easy, as well as making sure it is correct. Otherwise you are taking risks of many types. Such as, electrical issues, sound issues, etc. Just a suggestion.
Buck Ford F250... | Answered on Jul 17, 2010
Same thing happened in my dads F-250. First, I would say check the wiring. Could be a short. If not the wiring, the little motor for the wipers could be going bad. Not a very expensive fix either way.
Buck Ford F250... | Answered on Apr 15, 2010
try the fuel cut off switch, its a yellow rocker switch that when the vehicle gets into an accident or recieves major shock will disengage power to the fuel pump/thus no power im not sure of location on the trucks,my best guess would be glove box or passenger kick-panel area it will be marked as fuel shut-off
Buck Ford F250... | Answered on Jan 17, 2010
yes. more that likely if you look at the stereo it will give you a colour code as to what colour wires do what. if they dont then a simple google search for a stereo wiring diagram for each vehicle will be even better. if its just your speakers that are messed up then a neat trick to remember is if you take a AA battery and put the + side of the battery to the + side of a speaker wire and the - to the - then that speaker will come out. If the poles are backwards then the speaker will go in. good luck
Buck Ford F250... | Answered on Nov 23, 2009
go to auto zone site and use their repair info they might have something http://www.autozone.com/home.htm
Buck Ford F250... | Answered on Feb 26, 2009
You can locate your Harness Here Schoche.com Please Rate My Response! Thanks!
Buck Car Audio &... | Answered on Feb 05, 2009
How do reset the japanese languange to english in toyota vanguard nhzt-w58
Car Audio &... | Answered on Oct 14, 2019
plorer Stereo Problem - Ford Forum - Enthusiast Forums for Ford ...
www.fordforum.com > ... > General Ford Forums > General Tech
Nov 5, 2011 - The Eclipse AVN5504D stereo only displays eject cd, eject dvd, open. plus some asian writing at the top which I don't understand sorry.
Japanese navigation toyota,eclipse insert map disk solution ...
www.pakwheels.com > ... > In-Car Entertainment (ICE)
Oct 9, 2012 - 21 posts - ‎16 authors
Despite the radio having all the instructions in Japanese, it has been ... The Eclipse AVN5504D stereo only displays eject cd, eject dvd, eject ... More results from www.pakwheels.com
- avis des utilisateurs [ tradecarview ]
Buck Ford F250 F350 2002 02 Radio/stereo Wire/wiring Harness Logo
9 questions posted
Top Buck Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
handygirl911
handygirl911
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Buck Car Audio & Video
Most Popular Question
radio code ford
  • Car Audio & Video
