20 Most Recent
CIBA Vision Ford Focus 2007 Stereo/radio Wire/wiring Harness Plug Questions & Answers
Code for 6000cd rds eon please ,serial number
Recently purchased this decode software for my businessand it seems to be doing very well. I ran your serial number and received a code of 6092. Would be grateful if you would let me know either way if this code worked as I want to keep track and make sure I got my money's worth buying this software. You can reply/comment here or email me directly at:
[email protected].Thanks and I hope this works for you....
Code for model MO23560 a need hellp
code of 4981. Would be grateful if you would let me know either way if this
this software. You can reply/comment here or email me directly at [email protected].
Hi! I lost my code
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio. The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Ford service centre and get them to enter this code for you.
Connection/wiring dagram ford radio FCT006A2
2007 Ford Focus Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
I NEED TO UNLOCK MY FORD FOCUS CAR RADIO WHICH
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
The radio will have to be removed from the car dashboard .
Then please quote the SERIAL NUMBER found on a label on the radio casing
It normally begins with M ++++++
How can i find a code to ford 6000CD RDS serial
Your
Code is : 9193
Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
I'm looking for the radio code for my ford focus.
try your owners manual if nothing there try this web site you have to pay a little bit not sure how much you also can go to your dealer maybe? here is the site www.Radio-Code.com now ford is in with the uk vehicles this maybe because ford merged with fiat so they didn't have to ask for a bail out good luck
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
