20 Most Recent
Jl Audio Stealthbox Single 10" Chevy Blazer 4Dr 1995-2004 Medium Questions & Answers
How do i fix the latch on the drivers side door of a chevy blazer, i cant close the door/
If the door seems to be unable to close, look at the edge of the door to see if the latch striker has closed and is covering the slot where the door latch pin is supposed to seat. If the striker is covering the slot, simply pull on the door handle as if you were opening the door, and while holding the handle out, flip the striker bar out the way with your finger or a screwdriver. This happens occasionally on GM vehicles and is not a problem if you know how to fix it.
3/2/2015 4:25:03 AM •
Jl Audio...
Answered
on Mar 02, 2015
OIL PRESSURE
You should get a guage to test the oil pressure and not rely on the one that is in the dash.
2/3/2014 10:04:41 PM •
Jl Audio...
Answered
on Feb 03, 2014
What might be wrong with my 1995 blazer? the
Well to be honest the question and subject title is a bit vague. BUT! if your lights went out after installing the sub i would say check all your wiring from stereo to amp to speakers. If that isnt invloved and your lights have gone out start by checking your owners manual and looking up the fuse diagram for your vehicle. Check those fuses. The Fuse box in your vehicle is located to the left of the instrument cluster visible when the driver side door is open there is a cover with a latch turn the latch to open it. There may also be a possibility of it having a relay which would be located in the other fuse panel located under the hood of your behicle next to the air filter.
6/7/2011 1:14:51 AM •
Jl Audio...
Answered
on Jun 07, 2011
NO HEAT AT ALL
first... when you add antifreeze make sure you have all the air out of the system. you can accomplish this by adding antifreeze and squeezing the top radiator hose down toward where it meets the thermostat (be very careful of the fan). make sure all the air is out. top up the rad when you do this. look into the opening as well to make sure the antifreeze is moving. if it does not move there is a small chance you have put the thermostat in backward or it is defective (it happens)
if you have heat then you have fixed it. if not ... feel the hoses going into and out of the heater core. they both should be hot. if not the replacement may not be any good.
1/8/2010 3:59:00 AM •
Jl Audio...
Answered
on Jan 08, 2010
Engine turns off when ac is turned on will not
sounds like the compressor is trying to lock up and killing the engine. could also be the idle air control valve not idling the engine up to compensate for the extra load on the motor. if it not blowing out of the vents when truck is running more than likely a blend motor or the switch on the dash, if everything else on a/c panel works
8/28/2009 3:08:02 AM •
Jl Audio...
Answered
on Aug 28, 2009
