20 Most Recent T-Mobile Motorola Razor V3 Custom Cell Phone Car Charger Questions & Answers
Hey,
Take the battery out of the phone and locate the sim card. Remove the sim card and get an number 2 pencil with a good eraser and use the eraser on the gold contacts on the sim card lightly to clean up any corrision that built up on the contacts ( it will look black) . If that doesnt work go to your cell phone providers store your sim card got fried. they can set u one up for like $25
T-Mobile... | Answered on Feb 28, 2014
i found a simple way to unlock..a comapny i found where i found unlock instruction http://www.unlock-zone.com/ reach here u may get assistance
T-Mobile... | Answered on Dec 26, 2010
hi :) motorola K1 is a flip phone,when open flip no display,that mean phone ribbon was spoil.pls send for mobile technician to change a new ribbon. pro will solve.
T-Mobile... | Answered on Jul 06, 2010
For the symptoms your are giving, probably the best solution is to get a new phone. Sorry about that
T-Mobile... | Answered on May 21, 2010
buy the passcode for about 5 to 10 dollars on ebay.com
T-Mobile... | Answered on May 14, 2010
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
T-Mobile... | Answered on Nov 25, 2009
i've incountered your problem when i bought a car charger..the reason i know is that on the car charger itself. The car charger hava electronic parts inside on it to make the power of car battery will be stepped down into the power needed by your fon batterry..so,if these electronic parts particularly capacitors are not filtered to much the power which distributes to your fon battery.then you can hear unwanted noisy sounds to your fon everytime you are going to charge.So,if you can bring it to an electronic technician for check-up,go on.But if you have the knowledge to do it,then go on and investigate the possible defects i told you..
T-Mobile... | Answered on Oct 31, 2009
I ask AT&T how.They tell me for free
T-Mobile... | Answered on Oct 18, 2009
puk code, personal unlocking key. It is sim card related / specific, if you take the sim card out from the phone, the phone will work with another sim card.
The puk comes up when the pin code has been entered wrong 3 times. To get the puk code for your sim card, you have to call the service provider of that sim card. They are the only ones who can provide you with the right puk code for that sim card.
The puk code may also have came with the documentation of the sim card, if its a prepaid card the puk code comes on the documents or on the box of the product.
if your unable to obtain the puk code, get a new sim card.
also entering the puk code wrong too many times will eventually ruin the sim card forcing you to buy or contact your service provider for a new sim card.
There are no puk code calculators or anything that we can do about it, you can buy premium assistance and you will get this same response. Theres no other solution.
You have to contact the phone service provider of that sim card or replace the sim card.
Can't help you even if you paid.
T-Mobile... | Answered on Sep 10, 2009
usually in this case, the phone is stolen or picked up and the original owner of the phone canceled their account so whoever has the phone now cannot use it.
or the sim card and phone are incompatible with each other. (ex. at&t phone with t-mobile sim card, or vice versa) they just wont work with eachother.
T-Mobile... | Answered on Sep 05, 2009
You may have to call TMobile Customer Service to get it to work. I had to do that with Tracfone.
T-Mobile... | Answered on Aug 22, 2009
Check a cable connectors clean,restore a phone to factory settings.go to Menu/settings/initial setup/master reset/enter 6 zero ok. and then try to down load,should be ok.
T-Mobile... | Answered on Aug 18, 2009
You should check if your simcard is active first.
If it isn't, get a new one.
If it IS active, your phone has been blacklisted/barred.
You can either get a new phone, or have your phone's IMEI number changed, but you should note that IMEI change is ILLEGAL in most countries.
Have a nice day.
T-Mobile... | Answered on Aug 01, 2009
call tmobile and ask for tech support. tell them to resend the "over the air configurarion settings" or the "service packs" to your phone. Make sure to call from another phone.
T-Mobile... | Answered on Jul 31, 2009
no solution bcoz t mobile is waste
T-Mobile... | Answered on Jul 10, 2009
Start by taking the battery out and putting it back in.
While you're in the battery compartment, look for a little round sticker.  If it's red or has little red Xs on it, then your phone got wet.
T-Mobile... | Answered on Jul 08, 2009
Take it to your cell store. They should have software that will allow them to see the lock code. If they don't you will most likely have to refurb "erase the phone" Which customer service can talk you through. Good Luck.
T-Mobile... | Answered on Apr 21, 2009
default is 1234 give that a try
T-Mobile... | Answered on Apr 18, 2009
try this pass 1234/0000
T-Mobile... | Answered on Apr 01, 2009
T-Mobile Motorola Razor V3 Custom Cell Phone Car Charger Logo
Popular Tags
33 questions posted
Top T-Mobile Cell Phones Experts
Trimesh
Damen Wong
Damen Wong
Steve Allison
Steve Allison
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • T-Mobile Cell Phones
Most Popular Question
unlocking t mobile forn
  • Cell Phones
