20 Most Recent
Buck Petz: Monkeyz House for DS Questions & Answers
I Can't seem to reset petz my monkey family on my
I had the same problem with mine. What you do is you go into closet, and when the screen comes up that says, "Please don't turn off the power or remove the game card," with the gorilla and smaller monkey in a tree, yank the game card out. It may take a few tries, as that screen is only brief, and you might not get it at the right time. Then the screen will go a translucent white, like you can still see through it but it's still white. After that all you have to do is switch it off and back on again, reinsert the game card, and then it will say, "The save data has been corrupted. It will now be deleted." Then you press A and it goes onto the adoption centre door screen, ready for you to adopt your first monkey! I hope this helps, as it did with mine. Good luck with it!
How do you change the language back to english on
1. turn off the DS 2. turn it back on. 3. select Petz icon 4. press the globe icon at the lower right corner. 5. scroll right or left till you see the word "English" in the sentence. 6. select (yes) by selecting the "O" in the big blue box. 7. select the little suitcase icon in upper right corner. 8. select the icon that looks like a gear or flower.9. select the top icon (disk) at the left to save the new language setting. 10. then select yes by touching the "O" in the big blue box.should be good now, took me like 30 min b4 realizing I probably can just reboot the game and hopefully it will ask me what language...after i realized it was in Danish...i was able to locate the word "language", which is "sprog" in Danish.~Serena
How do i rest petz
When
you launch the game, before it gets to the main menu, the game shows a
screen of just the Ubisoft logo. During this time, press L, B, X and
Select at the same time. This will then ask if you want to really delete
the data. Confirm and it will wipe your save.
I've tried everything and I
When you launch the game, before it gets to the main menu, the game shows a screen of just the Ubisoft logo. During this time, press L, B, X and Select at the same time. This will then ask if you want to really delete the data. Confirm and it will wipe your save.
How do you reset petz monkeyz house? i bought it
Easy one I had the same problem. enter the closet the game tells you not to touch the power button or the card as soon as you see this screen remove the card quickly it will corupt the save after the game has only one option erase all data and start over.
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
When the game turns on
Pokemon crystal is a Game boy color game, there for it will not run the original Game boy.
What are some good catering services?
I recomenr you Alchemiq, it is a quality caterers https://alchemiq.com/catering-nyc/. They offer gourmet appetizers, fancy food stations, upscale cocktail catering, and event design
