20 Most Recent Washburn X10 Electric Guitar Questions & Answers
2answers
Can you tell me anything about S97056409
This is Washburn guitars official # 1 800 877-6863 they should be able to help?
2/27/2015 6:59:56 PM • Washburn X10... • Answered on Feb 27, 2015
2answers
I put a Seymour Duncan in my Washburn at the
Here is their site:http://www.seymourduncan.com/ This site might also help:http://www.gmarts.org/index.php?go=230 You may need a different or new volume control.
3/8/2013 7:39:58 PM • Washburn X10... • Answered on Mar 08, 2013
I need wiring diagram for
Search this site for one matching your configuration:
http://www.guitarelectronics.com/category/wiring_resources_guitar_wiring_diagrams/
1/12/2011 7:54:20 AM • Washburn X10... • Answered on Jan 12, 2011
What is the string holder at the bottom of the
I am thinking you mean the bridge area at the bottom this is where the strings are held or locked in place.
7/14/2010 8:16:01 AM • Washburn X10... • Answered on Jul 14, 2010
Need wiring diagram for washburn lyon guitar
Try this site:
http://www.guitarelectronics.com/category/wiringresources/
Find the schematic closely matching the resources of switches, pots, and pickups of your guitar.
6/15/2010 11:23:06 PM • Washburn X10... • Answered on Jun 15, 2010
I have a Washburn, House of blues, electric guitar
Here are two links that may or may not help:http://www.washburn.com/about-us/customer-service/contact-uscustomer-service.html and http://reviews.harmony-central.com/reviews/Guitar/product/Washburn/House+of+Blues+Edition/10/1
3/16/2010 10:05:20 AM • Washburn X10... • Answered on Mar 16, 2010
I have a washburn rr 2v and when it is plugged
Here are some things to check:
- Are all volume controls turned up 1/2-way? - Try a different guitar patch cable. - Does your amp have remote switchable inputs? Is your guitar plugged into the *active* channel on the amp? - Is the amp turned on?
2/24/2010 4:17:31 PM • Washburn X10... • Answered on Feb 24, 2010
I have the washburn wi65 pro and the volume is
The probable cause is either one end of the volume pot is broken, or the wire to it is broken. Test the control and wiring with an Ohmmeter.
1/13/2010 9:27:23 PM • Washburn X10... • Answered on Jan 13, 2010
Put a seymourduncan in my washburn at bridge. With
Either the pot is wired backwards (easily determined if volume increases in correct direction) OR the pot may be bad. Some defective ones can have a dead spot at the end.
ALSO check for splder splashes casing shorts.
ALSO check that terminals are NOT touching the wood as the BLACK PAINT is conductive and tied to ground.
10/20/2009 1:59:03 AM • Washburn X10... • Answered on Oct 20, 2009
2answers
What kind of strings are best for washburn X 10
the washburn X10 is an electric guitar.
first thing you you want to make sure of is that you ask for electric guitar strings
next consider what kind of music your are playing...
heavier music or really moody warm tones your going to want thicker strings
med to heavy guage
if you want clear crisp tones than go with lighter guage
light to med
lighter guages are also easier on the finger tips.
the sizes usually refer the the smallest string on the bottom or the first string.
9 is the light 10-11 is med 12 is heavy
you might also want to consider nylon coated strings
they last longer
have great tone
easy on the fnger tips
but they cost more
7/18/2009 1:30:17 AM • Washburn X10... • Answered on Jul 18, 2009
2answers
I have a Washburn WCD18DCE guitar and I need to change the battery
Depending on the year, it could be a couple different places. There could be a little battery compartment on the outside body of the guitar. Sometimes they are separate from the other electronic controls. Sometimes that are part of the controls or even part of the guitar jack. But if it is on the outside of the body, it will have a little door that pops open when you push a tab. You just have to look and see if there is a little rectangular door. If you don't have a little door, then it is likely tucked inside the guitar, just inside the sound hole. If it is in there, then you will probably see a little cloth pouch with wires coming out. Thats where the 9v battery is kept and plugged in. It's usually held to the body with velcro.
8/8/2023 9:15:23 PM • Washburn Music • Answered on Aug 08, 2023
Washburn pro x series wiring diagram pictures
You can try looking for a wiring diagram for your Washburn Pro X series guitar at the following places:
  1. The Washburn website: The manufacturer's website may have wiring diagrams available for download for their guitars.
  2. Online forums: Online guitar forums such as the Washburn Forum (https://www.washburn.com/forums/) may have wiring diagrams posted by other users, or you can post a request for one
  3. Luthier: A Luthier or guitar repair specialist may be able to provide you with a wiring diagram for your guitar.
  4. Online guitar parts retailers: Some online guitar parts retailers may have wiring diagrams available for download on their websites.
Please note that the wiring diagram may vary depending on the specific model and year of your Washburn Pro X series guitar. It's best to check the wiring diagram for your specific guitar model to ensure that it is accurate.
1/23/2023 3:33:17 PM • Washburn Music • Answered on Jan 23, 2023
2answers
I have a Washburn electric serial # S10102616 and I wanted to know if it's real and how old is it?
contact the maker an ask this. only makers keep Sn logs, on product, some are even coded in Julian format. nobody can guess REAL ,unseen and not dismantled seen/ zero that. Washburn Guitar's? if yes why not ask them first. https://www.washburn.com/customer-support/ only they know and can tell ,unless you google to the end of time and get half yes and half no. see?
9/25/2022 4:59:20 AM • Washburn Music • Answered on Sep 25, 2022
2answers
I have a washburn bass guitar with serial no. 721171 and need manufacture date.
only maker has S/N records, as them they have web site. google finds it in 1second flat.
8/26/2022 3:37:05 PM • Washburn Music • Answered on Aug 26, 2022
Serial Washburn mirage pro serial is 833864 How value ? Where it made ? Thanks
Your best bet is to take it into a reputable music store that sells everything from custom made high
end modell guitars, electric, acoustic/acoustic electric to classical. Get an appraisal by a professional DO NOT GO TO A PAWN SHOP OR ANY BUY AND SELL ONLINE SITES (Craigslist, Kijiji, eBay etc.) They will either low ball you to try and rip you off or won't have a clue what they're talking about. Long & McQuade has always been solid for me and there's this really nice high end music store in my city that are proffessional musicians (university degrees up the the Ying/Yang)
I doubt this is much help but it's what I would do. The other most obvious is to lookup the Washburn website and most likely they'll have online help via I.M.
7/7/2019 7:28:34 AM • Washburn Music • Answered on Jul 07, 2019
How can i find an oscar washburn guitar year of assembly?
Try a Google search. Or a Wikipedia search.
6/29/2019 5:19:27 PM • Washburn Music • Answered on Jun 29, 2019
Washburn X10 Electric Guitar Logo
15 questions posted
Top Washburn Music Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
Are you a Washburn Music Expert? Answer questions, earn points and help others
View Most Popular
Washburn Music
  • Washburn Music
Most Popular Question
need wiring diagram
  • Music
